-   -   Cam Expert Needed (https://www.offshoreonly.com/forums/general-q/111900-cam-expert-needed.html)
Donman 09-07-2005 06:06 PM
Cam Expert Needed
What cam would you run in this engine?
Gen VI 454, bored .030", 4.25" stroke, 6.385" rod, (489 cubic inches ), 10.0 : 1 compression, Merlin VR square-port heads, Strip Dominator intake, 800 Holley DP, full MSD ignition, Stainless Marine Gen III exhaust. This runs a factory style roller. I am currently running a Crane 731. I have the engine apart right now and would like to bump it up. I was running 8.5 compression, but bought new pistons. Reversion is not an issue, the exhaust is dry up to the tip.
Should I keep my current cam?
What do you guys suggest?
I can have a custom-grind made also....
rmbuilder 09-07-2005 06:26 PM
Re: Cam Expert Needed
HigherPower,
Where will you prop for peak power/max WOT? Target HP?
Bob
Elite Marine 09-07-2005 06:26 PM
One of, if not the best is:
Bob Madara - RMBUILDER on OSO
[email protected]
Donman 09-07-2005 09:19 PM
Originally Posted by rmbuilder
HigherPower,
Bob
I would like to see my MAX rpm at about 5800.
I would like to get about 550 hp out of this combination.
Thank you for your response. The MAIN reason I am a member here is because of the excellent technical discussion.
rmbuilder 09-08-2005 10:10 AM
Higherpower,
Those heads have very strong low/mid lift flow characteristics. The runner size/CSA will also provide good velocity for this displacement. Your target of 550 HP brings you in @ 1.13 HP/CID which would be no problem with a cam change. I would closely watch timing and octane and determine the exact compression ratio with the new components.
Bob
Donman 09-08-2005 10:58 AM
So...... what kind of specs do you suggest?
Can you grind one?
Pat McPherson 09-08-2005 01:00 PM
Can you grind one?
Crane 741 or Custom Grind...
Hey you want to sell that 731? If so PM me the $$...
Donman 09-08-2005 01:12 PM
Yes Pat, I will be selling it as soon as I have replacement in hand.
Prowler 09-08-2005 01:17 PM
the new 741 falls off at 5500 rpm's now and the 731 falls off at 5200 rpm's trust me i know.so now it's time for another cam change.
Pat McPherson 09-08-2005 01:48 PM
741 only to 5500? in a 454 or 502?
Yes, I would agree that the 731 is good to about 5200 in a 502...
