-   -   vent tube relocation? (https://www.offshoreonly.com/forums/general-q/111938-vent-tube-relocation.html)
yadamnright 09-08-2005 08:55 AM
I swapped a stock weber carb with a nickerson/holley carb and I'm not sure where the fuel pump vent tube should be relocated. The weber has provisions for the tube, but does the holley?
Wobble 09-08-2005 09:12 AM
Re: vent tube relocation?
Most Holleys don't. I installed a fitting in the air cleaner housing that will dump fuel into the venturi in the event that the pump seal fails. Do not use any of the ports on the side or base of a Holley for this as it could mess up your carb calibration by allowing air to be sucked thru the pump.
RedDog382 09-08-2005 12:14 PM
Some aftermarket flame arrestors (Gaffrig) have a nipple on them to attach it to.
Kidnova 09-08-2005 11:22 PM
Nickerson's did my carb...great job. As RedDog said Gaffrig arrestors have a nipple to stick the line on, at least mine does.
yadamnright 09-09-2005 07:30 AM
Thanks for the replies. I'm using a K&N spark arrestor so I'll have to fabricate a fitting that will return the fuel back to the carb.
mopower 09-09-2005 07:45 AM
K&N does sell such a part if you check it out :cool:
