-   -   How do I do this? (https://www.offshoreonly.com/forums/general-q/112414-how-do-i-do.html)
risky 09-14-2005 08:24 PM
How do I do this?
I have stainless thru hull exhaust that has inserts to lessen noise. I would like to remove the inserts to improve noise (make louder is improving sound to me ) They look to be soldered, can I just cut these out or do I have to change the tips? thanks vic
REBEL4845 09-14-2005 08:40 PM
Re: How do I do this?
I tried to cut out what your talking about and destroyed a set of tips. They are welded in there pretty good. If you are good enough to get them out, it will help your performance big time and it sounds alot better.
jpclear 09-14-2005 08:59 PM
Oh, I don't know about just hacking away. Some (actually most) of the better tips have flapper systems built in to reduce back-splash and reversion, and THAT you would NOT want to remove. If you can give us more info. on just whose and what tips you have, we could probably advise more intelligently. --- Jer
Slick02 09-14-2005 09:08 PM
Sounds like tthe Corsa baffled tips that came on my 24 Outlaw....Tried drilling, a hole saw,,,finally gave up and changed the tips for a set from Eddie marine..
sleeper_dave 09-15-2005 01:28 PM
I have corsa tips in mine. I was told by the seller that the backpressure they provide helps performance. If i can gain performance by removing them, and possibly make money selling them, i'd do it. Louder is better IMO also. I have silent choice so i wouldn't be a nighttime bother without them in there.
Do those corsa mufflers hurt performance?
Mudball 09-15-2005 07:42 PM
Not necessarily with black motors, but YES with HP motors...
Kent
risky 09-18-2005 08:40 PM
Gave it a try today, took a flat screwdriver and hammer broke 3 small solder connections easily got muffler insert moving. But there is a problem the solder remains on the inside of the pipe stop the insert from coming out. So, tommorow will gring off small solder pieces and see what happens. Doesn't seem to affect flappers. These a 4" angled thru hulls about 8" out of transom lot of room to work. If I screw up trick has some for 70.00 each.
