-   -   500 HP What valve springs to use? (https://www.offshoreonly.com/forums/general-q/112765-500-hp-what-valve-springs-use.html)
dean brown 09-20-2005 08:31 AM
I have a 1999 Formula Fastech with 500 HP motors. Have always heard that after a few hundred hours that valve springs start breaking. I'm pulling heads this winter, what is best springs to put back into motor. Any suggestions?
rmbuilder 09-20-2005 09:06 AM
Re: 500 HP What valve springs to use?
Dean,
The Crane replacement is Part # 99896. Depending on your lifters and installed ht. you can also use the Isky #8005/8205 (upgrade S/SP series) or the K-Motion 850 with good results.
Bob
JCPERF 09-20-2005 09:07 AM
What bob said and i have good luck with 929 CompCams too. :D
37Talon 09-23-2005 07:58 AM
I have a 55 gallon drum of broken HP 500 valve springs....switched to Comp 929-16 haven't broken a single one!!
thunderusone 09-24-2005 12:55 AM
Comp 929-16 no problems so far.
