Neutral saftey switch problems
I have Gaffrig controls and have not opened them up before. Before I do is the nuetral saftey switch located with the shift levers or somewhere else?
Re: Neutral saftey switch problems
It's in the shifter portion of
the throttle/ shift quadrant. |
Hard/time consuming fix?
Take out the 4 screws that hold in the
throttle/shift quadrant, then lift it out. You'll see 2 small switches that are activated by the shift levers. I don't recall how the switches were fastened. Worst case, you may have to split the sections of the quadrant to gain access to the screws. If you have to do that, you may want to disconnect the cables and wiring and remove it for disassembly ( so your not dropping pieces down through where the quadrant mounts ) I had gaffrig controls on my old boat, and the only starting problem I had with it was caused by a faulty slave solenoid back at the engine. |
1 Attachment(s)
be careful as there are little detent balls and srings in there that will fall out when you take a part
| All times are GMT -5. The time now is 04:42 PM. |
