-   -   Help W/ Alpha one (https://www.offshoreonly.com/forums/general-q/113109-help-w-alpha-one.html)
grand lake 09-26-2005 08:24 AM
Help W/ Alpha one
Should oil from the upper gear assembly reservoir leak into the u-joint bellows through drive gear assembly. I noticed the oil leaking due to hole in u-joint bellows, which leaked onto lower unit.
Biggus 09-26-2005 09:24 AM
Re: Help W/ Alpha one
No, the upper yoke seal has failed and usually there is a deep groove worn into the yoke as well. Replace the yoke and seal.
Outdrive1 09-26-2005 09:27 AM
After you replace the yoke seal on your drive you'll want to replace that bellows too.
grand lake 09-26-2005 11:52 AM
Thanks for the feedback.
