TRS gimbal question
Is there a difference between TRS gimbals depending on the year manufactured?
Re: TRS gimbal question
Not that I am aware of, other than the thru-transom steering arm and it's mating pivot pin went from the original splined connection to square in later production. --- Jer
Thanks for the info.
Both the arm and gimbal ring went from spline to square, but not at the same time. So you can have a spline/spline, spline/square, or square/square upper swivel pins with corresponding arm and ring.
Jon |
Hmmm, never heard that before. I though they switched to square because the splines had a bad habit of freezing in place.
Originally Posted by Audiofn
You got it and the Square/Square is the best out of them all. The Spline units were much weaker. I just swapped out a spline spline unit on my Donzi because I did not want to have to worry about it.
Jon |
I believe I have one with splines, and one with square/square steering. I will not be putting a lot of HP through them. I was just making sure the dimensions are the same before i plan to install them. can you change the bellhousing to the square/square configuration or do you need everything to switch over. I picked up the transom assembly for $100 with low hours.
Jon |
| All times are GMT -5. The time now is 09:01 PM. |
