-   -   casting number help on sbc (https://www.offshoreonly.com/forums/general-q/113187-casting-number-help-sbc.html)
BajaRunner 09-27-2005 09:17 AM
Im looking at buying this engine and want to verify it is a 350.
the casting number that would be the driver side right by where the bellhousing meets is 57lgsg1 and the other is on the back of the engine right by the freeze plug and its h10627638.
i also was wondering if it was a 2 bolt or 4 bolt. supposed to be out of an 89 chevy truck.
thanks in advance
jason
Outdrive1 09-27-2005 09:45 AM
Re: casting number help on sbc
I can't match your numbers up to anything. The casting number should be by the bell housing and should be six or seven numbers with out letters. You should also have a engine suffix code stamped on a block pad located immediately forward of the right hand or passenger side cylinder head. The entire engine code contains the assembly plant, month and day. Your suffix code should have a letter, four numbers and two or three letters at the end. Here are the casting codes for small blocks.............
Casting Years CID HP Main Notes
140029 1980-84 350 2
330817 1970-80 400 150-180 2
355909 1975 262 2
355909 1976-79 305 2
360851 1975-76 262 2 Monza V-8
361979 1978-79 305 2
366245 1978-82 350 N\A 4 Bowtie High Tin
366286 4 Bowtie, Aluminum, siamesed, straight nodular iron main caps, 2-piece seal, 4.00-4.150" bores, 2.45" main journals
366287 4 Bowtie, Aluminum, siamesed, straight nodular iron main caps, 2-piece seal, 4.00-4.150" bores, 2.45" main journals
366299 4 Bowtie, Aluminum, nodular iron splayed caps, wet sump, 4.00" bore
393288 1965-67 283 2
460703 1978 350 175-220 4 corvette uncertain
460776 1978-79 305 2
460777 1978-79 305 2
460778 1978-79 305 2
471511 1979-82 267 2
3556519 1958-62 283 2
3703524 1955 265 195 2 No oil filter corvette
3720991 1956-57 265 210-240 2 corvette
3731548 1957 265 2 No side motor mounts
3731548 1957 283 220-283 2 No side motor mounts, corvette
3737739 1957-64 283 170-290 2 220-290hp Corvette's
3756519 1958-62 283 170-315 2 passenger, corvette
3782870 1962-67 327 250-375 2 passenger, chevelle, corvette
3789817 1958-68 283 2
3789935 1961-66 283 only 170-315 2 passenger, corvette
3790721 1962-65 283 170-220 2 Chevy II recessed oil filter boss
3790721 1965-66 327 250-350 2 Chevy II recessed oil filter boss
3791362 1962-67 327 250-350 2 Chevy II recessed oil filter boss
3792563 1965 327 2
3792582 1964-65 283 2
3794226 1958-63 283 170-195 2 passenger
3794460 1962-64 327 2
3814660 1968-69 327 2
3830944 1963 327 2
3834810 1964-66 283 195-200 2 passenger, chevelle, truck
3834812 1962-63 283 170-195 2 passenger, commercial trucks
3837739 1958-62 283 2
3849852 1957-66 283 multiple 2 truck, passenger, chevelle
3849935 1965-67 283 2
3858174 1964-67 327 275-350 2 passenger, chevelle, corvette, trucks
3858180 1964-67 327 250-375 2 passenger, chevelle, corvette
3858618 1968-76 350 2 unverified
3862194 1965-67 283 195-220 2 Chevy II recessed oil filter boss
3862812 1962-64 283 2 unverified
3892657 1967 302 290 2 Z28 Camaro
3892657 1967 327 210-350 2 Passenger/Chevelle/Corvette/Camaro
3892657 1967 350 295 2 Camaro
3896944 1967 283 195 2 Passenger/Chevelle
3896948 1966-67 283 2
3903352 1967 327 210-350 2 Passenger/Chevelle/Corvette/Camaro
3914636 1968 307 200 2 Truck/Passenger/Chevelle/Chevy II
3914653 1968-73 307 2 unverified
3914660 1968 327 210-300 2 Passenger/Chevelle/Chevy II/Camaro/Corvette
3914678 1968 302 290 2 Z-28 Camaro
3914678 1968 327 210-350 2 Passenger/Chevelle/Chevy II/Camaro/Corvette
3914678 1968 350 295 2 Chevy II/Camaro
3932371 1969-73 307 2
3932373 1968-73 307 2
3932386 1969 302 290 4 Z-28 Camaro
3932386 1969 327 2 ?? Unverified
3932386 1969 350 300/350 4 Passenger/Chevelle/Chevey II/Corvette/Camaro
3932388 1969 350 300 4 Passenger/Camaro Rare? See FAQ on site
3932388 1969 302 290 4 Z-28 Camaro Rare? See FAQ on site
3951509 1970-80 400 only 150-265 2/4
3951511 1970-80 400 255/265 2/4 Some replacement blocks had 2-bolt main caps
3956618 1969 302 290 4 Z-28 Camaro
3956618 1968-69 327 235 2 Passenger
3956618 1969 350 250-350 2/4 Passenger/Chevelle/Chevy II/Corvette/Camaro
3956632 1969 307 200 2 Truck/Chevelle/Chevy II/Camaro
3959512 1962-67 327 2 Was also used for some replacement blocks
3970010 1969-69 350 255-350 4 Truck/Passenger/Chevelle/Chevy II/Corvette/Camaro
3970010 1969 302 290 4 Z-28 Camaro
3970010 1970-80 350 145-350 2/4 Truck/Passenger/Chevelle/Chevy II/Corvette/Camaro
3970014 1968-79 350 only 200 & 255 2/4
3970014 1970-75 350 2/4
3970020 1970-73 307 2
3970024 1969-73 307 2
4715111 1980 305 2
6259425 1969-76 350 2
10036033 350 4 Goodwrench crate motor, 2-piece rear seal, "Hecho en Mexico"
10051182 2/4 Bowtie, 3.75"-4.30" bores, 1 or 2-piece rear seal
10051184 1986-up 350 N/A 4 1 piece rear main seal. BOWTIE
10051184 1986-up 350 4 Bowtie, 4.00"-4.155" bores, 1 or 2-piece rear seal
10054727 1986-up 350 2/4 one piece rear seal, some "Made in Canada"
10066036 350 2/4 Target Master/Goodwrench crate motor, 2-piece rear seal, "Hecho en Mexico"
10066038 1994 350 4 Goodwrench crate motor, 2-piece rear seal, "Hecho en Mexico"
10090511 1990 350 375 2 LT-5, ZR1 Vette, 375hp
10125327 1992-96 350 300 & up 2/4 Gen.II LT-1, reverse flow cooling
10125327 1996-96 350 300 & up 2/4 Gen.II LT-4, reverse flow cooling
10134996 4 Bowtie, Aluminum, 4.125" bore 2.65" main journals
10153558 1991-92 350 375 4 LT-5, ZR1 Vette, 375hp
10168588 1994-96 265 2 L99, Gen.II, 4.3 Liter V-8, Caprice, reverse flow cooling
10199001 1993-95 350 4 LT-5, ZR1 Vette, 405hp
10243878 1996-97 305 2 Vortec truck, roller cam, one-piece rear seal
10243880 1995-00 350 2/4 Gen.I crate motors and "ZZ4", roller cam, one piece rear seal
12550592 1997-99 346 345 crossbolted block, Gen.III, "LS1"
12559846 1998-99 346 345 crossbolted block, Gen.III, "LS1"
12560621 1998-98 346 345 crossbolted block, Gen.III, "LS1"
12562174 1998-98 346 345 crossbolted block, Gen.III, "LS1"
14010201 1980-85 305 2
14010202 1980-85 305 2
14010203 1980-85 305 2
14010207 1980-85 350 190 & up 2/4 corvette
14010209 1980-85 350 4
14010280 1979-82 267 2
14011064 1982-86 350 N\A 4 High Tin
14011148 1987-89 350 Roller cam, one-piece rear seal
14016376 1979-82 267 2
14016379 1977-79 350 up to 225 2/4 corvette and others
14016381 1980-84 305 2
14016382 1979-84 305 2
14016383 1980-85 305 2 Truck
14079287 1986-90 350 Truck
14088526 1987-89 350 Roller cam, one-piece rear seal
14088548 1986-88 350 205 & up 2/4 corvette and others
14088551 1986-87 305 2 one-piece rear main seal
14093627 1987-91 305 2 Roller cam, one-piece rear seal
14093638 1987-95 350 2/4 Roller or flat tappet cam one-piece rear seal
14094766 1986-up 305 2 One-piece rear seal
14101148 1988-up 350 205 & up 2/4 1 piece rear main seal. Late model roller non LT1
14101148 1987-90 350 4 One-piece rear seal
14102058 1987-91 305 2 Roller cam, one-piece rear seal
14316379
22551656 4 Rocket block, 4.00"-4.190" bores, 2.45" main journal sizes, splayed caps, dry sump, 2-piece rear seal, 9.025" deck
10046164 1986 305
3932338 1962-67 283 2
3789817 1962-67 327 2 truck
376450 1978 350 175-220 4 corvette uncertain
12560626 1998-00 346 345 crossbolted block, Gen.III, "LS1"
12559378 1998-00 346 345 crossbolted block, Gen.III, "LS1"
12561168 2001-04 346 350-405 crossbolted block, Gen.III, "LS1/LS6"
12568952 2005 364 400 "LS2"
BajaRunner 09-27-2005 09:58 AM
I know.. I usually have good luck finding them, and when the guy read them to me, it didnt make any sense.
Prater 09-27-2005 10:31 AM
http://www.mortec.com/
BajaRunner 09-27-2005 10:33 AM
i tried them too with no luck. the only thing i have found is googling the 57**** number and there was one thread of a guy trying to find the same thing, but the link was gone.
