-   -   502 MPI Fuel pressure? (https://www.offshoreonly.com/forums/general-q/113854-502-mpi-fuel-pressure.html)
92nsx 03-27-2014 02:26 PM
Originally Posted by mike tkach (Post 4096748)
i got this information from a merc tech that works on them all the time,he told me that i should have 43 lbs with the engine running,guess what,i had exactly 43 lbs.that ruled out fuel pressure being the issue.i will add that with the key on but engine not running the pressure will be lower.
I found it on page 1B-8 Fuel Pressure (Running) 43 psi (248 kPa)
Gen VI engine: So engine running (idle) it should be 43. With just the key turned to on (engine off) 34-38
Every one wins :)
Originally Posted by pwrboatn (Post 4096776)
What should the fuel pressure be with key on engine not running while the fuel pump is running?
See above
Cole2534 03-30-2014 06:46 PM
Mike,
On that 502 you mentioned in the thread about fuel pressure, where did you take your readings?
Curious because I'm thinking over the sender placement on my fuel system, which is directly after the pump. I don't like this location, but it was physically the best place I could put it without getting into a weird plumbing situation. Off the end of the fuel rail would be best, but I'm not sure it will clear the intake plenum.
On the other hand, we do really care about the exact pressure? If the dash gauge is a couple psi off the actual rail pressure, and you KNOW this, then I think it's a moot point.
All you really want to know is that you're maintaining regulator set point throughout the RPM/load range.
mike tkach 03-30-2014 07:57 PM
Originally Posted by Cole2534 (Post 4098469)
Mike,
there is a schrader valve ,it is located on the front of the engine just below the the upper plenum.
pwrboatn 04-01-2014 02:53 PM
Every one wins :)
See above
Roger that. Thanks boss. I was told by a perf mech to bump the pressure up a lil above factory this sound about right?
Bang Bang 05-26-2014 05:42 PM
43 psi idle and with vacuum hose to plenum connected?
Is the difference of 36 to 43 psi caused by the vacuum at idle?
