-   -   Imco 1000 (https://www.offshoreonly.com/forums/general-q/114445-imco-1000-a.html)
RBeyer 10-16-2005 10:42 AM
Imco 1000
Any thoughts on the new Imco 1000 drive?
Back4More 10-16-2005 11:21 PM
Re: Imco 1000
1 Attachment(s)
Looks great, kinda expensive at $35K per drive-line.
The gears look massive but the shafts look like they have weak spots with the smaller dia in them.
Hope they work out well, us power boaters need more Bravo alternatives.
Didn't understand what they meant by having an adjustable X height without unbolting anything???
Sean H 10-16-2005 11:26 PM
Re: Imco 1000
35k? holy chit for a bravo replacement? you are in #6 or arneson territory (or less) for that kind of money...
Mr Gadgets 10-17-2005 05:00 AM
Re: Imco 1000
Back4more,
where did you see the article on this drive? I have been talking to Imco about it for several months. It is suppose to be available in Feb.. last I heard.
They will only sell it as a package, hence the $35k price tag. I was told that includes the drive, standoff box with transmission, their HD transom assembly and full hydraulic steering and if I remember correctly their tilt wheel on the helm. So all in all, it is a lot of hardware for the money, but not just a bolt on swap for a Bravo.
I am interested in how this all works out.. Imco has been getting a lot of complaints on their stuff and the way they handle complaints.. Is this the answer, time will tell.
Dick
Turbojack 10-17-2005 05:46 AM
Re: Imco 1000
Article is in current HOT BOAT Magazine. Rated at 1000hp & 6 month limited warranty.
Mr Gadgets 10-17-2005 06:48 AM
Re: Imco 1000
Thanks Turbo,
I will have to pick that one up.. Seems the wife let Hot Boat expire!! May be time to see about updating the wife!!
Dick
KAAMA 10-17-2005 08:26 AM
Re: Imco 1000
What horsepower level did IMCO rate their last Extreme Advantage SC? Was it something like 750hp or 850hp depending on the weight of the boat? And from what I read from guys here on OSO they still had what sounds like many failures---and the failures seem to have stemmed from even how IMCO may have assembled the drives because even with light power their Extreme SC only lasted a few hours with some guys. It sounded like the Merc XR drive was more dependable than the supposedly beefier IMCO Extreme SC with the same kind of power. I have read a lot of different situations/testimonials (pros & cons) concerning IMCO's Extreme SC vs the Bravo XR---enough not to feel confident in purchasing one of IMCO's drives. Now they have this new IMCO 1000 and I wonder how it will do.
The question is, is 150-200 of additional HP rating going to really make the difference with IMCO's new 1000 drive? I think that being able to raise/lower the "X" without removing anything is pretty trick. It looks to be an interesting drive and I hope it does well, but I guess we will see.
Turbojack 10-17-2005 02:02 PM
Re: Imco 1000
If you look at the pictures of the gears fpr what it is worth they are close to the design and size of the #6 gears.
I will sit back & wait to see what the outcome will be.
RBeyer 10-18-2005 09:02 AM
Re: Imco 1000
I received an E-mail back from Imco they say it is a direct bolt on replacement. At almost 36K I will wait and see. Thanks for the input.
Mr Gadgets 10-18-2005 08:28 PM
Re: Imco 1000
By a bolt on swap, I meant you dont just switch the outdrive, the whole drive train back of the motor needs to be addressed.. It is a direct replacement, but you are replacing everything.
What does a #6 cost with transmission and steering and transom assembly? If I were to build a boat from scratch, I would consider it.. But like so many things.. time will tell.
Dick
RBeyer 10-18-2005 09:51 PM
Re: Imco 1000
Understood. I agree that time will tell.
tomcat 10-19-2005 07:25 PM
Re: Imco 1000
Very interesting...how do they get the 2 3/8" vertical adjustment? The trim cylinder looks short, how much can it raise the drive for trailering?
Boomer 880 10-19-2005 07:35 PM
Re: Imco 1000
What happened to the 4X4? Did it not workout for IMCO? I forget what that was rated at.
Outdrive1 10-19-2005 11:30 PM
Re: Imco 1000
The drive you are reffering to was a Bravo replacement, this drive has no trans in it similar to the 4x4 drive. The trans is in the box. Any of the Bravo type drives with built in trans's (Bravos, Xrs, Imco's, Teagues) are not rated for big hp(lets say 1000hp). This set up would bolt on to a transom that has been set up for a Bravo drive but you would need their transom bracket, extension box with tranny, and drive. Along with ext steering probably built into the box itself. It's expensive but what are your alternatives other than changing to a number six or arneson and moving your motor foward to accept a tranny before the transom.
Sean H 10-20-2005 12:23 AM
Re: Imco 1000
arneson puts the tranny in the box for the bravo conversion for less money than the imco... and probably much more reliable and better choice of props...
articfriends 10-20-2005 01:13 AM
Re: Imco 1000
1 Attachment(s)
I was wondering the same thing,I remember they were big bucks but they still used a regular imco lower. My motor is breaking lower xr gears but everything else is holding up so even a b-max wouldn't make any difference,Smitty
PatriYacht 10-20-2005 07:49 AM
Re: Imco 1000
Knowing Imco's reputation for reliability and customer service, I'd rather have Arnesons or Konrads at half the price.
