-   -   CMI E-Tops for 272 sr-1 Formula (https://www.offshoreonly.com/forums/general-q/114580-cmi-e-tops-272-sr-1-formula.html)
mtgbiker 10-17-2005 07:19 PM
Has anyone installed a set of CMI E-Top's in a 88'-90' 272 sr-1 Formula?
I posted in the Formula section with no reply and need advice.
CayFomula 10-17-2005 09:38 PM
Re: CMI E-Tops for 272 sr-1 Formula
Mtgbiker, it doesn't look like the 272SR1 owners did a Lot of mods to these. I have one that I have did quite a bit to but no help to you on the exhaust, this is one of my present limitations. I am running the standard Stainless Marine manifolds with Whippled 454s. I think Mopar used IMCOs or Gills on his if I am not mistaken.
Ian
Slick02 10-18-2005 07:08 AM
Ok,,I'll step in,,a few years back I had an 88 272sr1 with twin 454s,,,when I put the new motors in the center to center specs( I think it was 33") wasn't spaced far enough apart to use the Lightnings or the CMI's, I ended up moving the engine hatch ram and using Bassett headers.
Hope this helps.
Nick
mtgbiker 10-18-2005 09:58 AM
Going to be pricey, but I believe CMI and Trick will build a set for my rig. I just need to double check the center to center measurements as noted.
RedDog382 10-18-2005 08:59 PM
I went through this on my 311 years ago. If you have a silent thunder platform on you Formula, you might have a problem with reversion. The thru-hulls are mounted higher than standard, causing the tailpipes to be almost horizontal. 3" rise CMI's would not work on my 311 wtihout cutting a lot of structural fiberglass.
Slick02 10-19-2005 09:09 AM
For enough money you can get anything built,,,at that point in my life the budget was alot slimmer than it is today..had to use what was available across the counter..
