cost to freshen
How much should one expect to pay to freshen a pair of 420HP mercs? They have good compression, and run good, but Id still like to go thru them and get new rings, bearings, timing chains, valve jobs, gaskets, and then have the carbs dialed in. The only reason i would like to do this is because I dont really know the history of these motors.
Re: cost to freshen
:D
Re: cost to freshen
If you take to a motor guy with a dyno by the time you are done you would be very lucky to be at 5k a motor but prob more |
Re: cost to freshen
10k to freshen a pair of stock mercs? I can see if I needed cranks, pistons, rods, etc. I'd be better off buyin some crate 502's for 10g.
Re: cost to freshen
Are they high hours?
Re: cost to freshen
I had my 502 done over here in South Bend by a reliable race shop for 3600.00. I had him do it for the same reason that you want it done. He found all kinds of problems. Glad I did it. He did everything you posted and put it on his dyno.
Re: cost to freshen
2500/pc
Re: cost to freshen
I Would Say 2200 To 2500 A Motor.
Re: cost to freshen
One motor is a crate merc 454/425, and the other is a 400 cylone that someone supposedly rebuilt to 425 specs. The hours are unknown. The crate merc motor runs real strong, it will pull to 5200. The rebuilt cylcone runs good, but only pulls to 4500, which makes me think valve springs are weak. Either way, Id like to have them gone thru, and set up on a dyno.
Re: cost to freshen
1 Attachment(s)
And to give you an idea of estimates, I was originially quoted $2900. per motor to rebuild. Now $6000. All unforseen extras..... Any questions?? :D |
| All times are GMT -5. The time now is 01:24 PM. |
