oil flow direction ?
so should the oil got from block to cooler to filter to block OR block filter cooler block ?
Re: oil flow direction ?
1/ Some say block-filter-cooler-block.
2/ I prefer block-cooler-filter-block. This is because building a cooler involves a lot of soldering and I am always afarid there will be some solder balls that will get loose after time and get into motor. I beleive OEM is method #1 |
1 Attachment(s)
This is how we would do it
I cant open the darn file can you explain it please
I have exactly the same philosophy as Wobble. Especially true with used/reused coolers and lines.
1 Attachment(s)
lets try this
out of the block into the cooler into the filter assy back to the block |
Hmmm, warmer oil flows easier through filters, Ill stick with the tried and true Merc method of block, filter, cooler.
| All times are GMT -5. The time now is 02:10 AM. |
