454 stroker qeustions
Prices will be middle of the ground:
Parts
Scat 4340 Crank $799
Scat 4340 I Beam rod $359 or Scat H Beam Rod $479
Probe Piston Ring Kit $699
Clevite H Bearings Rods and Mains $140
Labor
Balance Assembly $200
Clearance Block $150
This kit would support 700HP
Chris
Parts
Labor
Chris
i am def. going to use forged pistons and crank. and i want to stay around the 9:5:1 ratio on the comp. i really would like to buy everything from one place as a kit or something and then just bring my block to my machine shop and have it done. the world stroker parts say there already balenced. is that just a bore and bolt in kit?
You may want to consider using a 502 block, since you're replacing all the internal parts anyway. The bigger bore pistons cost about the same, and you'll have a 540/547/555 when you're done. The 502 block is a lot stronger, and has blind head bolt holes, among other advantages. I found mine at a machine shop for $750, machined and ready to assemble. A lot of extra torque and hp for a little money. Just a thought.
I built a 489" (.030 over bore) using a Gen VI block. I shopped the internet for best deals.
I used:
Scat forged crank $600
Eagle H-beam rods (6.135" length) $350
SRP forged pistons (10 to 1 comp.) $525
No block clearancing was needed, but I did zero-deck the block, among other things. I`m running rectangle-port Merlins and a .612" roller cam.
It runs good, plenty fast in a 22' Baja.
I used:
I used:
I used:
Gen 4 blocks may require grinding in the pan rail area so the rods have clearance while in rotation. Depending on rod design and the block this can be minimal to a mild grinding job.
Zero decking is bringing cutting the block deck surface down till the piston face is equal to it or "Zero" deck. This enhances the flame travel and compression by optimizing the quench area.
Chris
Chris
Originally Posted by amer3
i have a 496 for sale just got back from machine shop. will sell right call 314 265 3876 john
