509s w/ b&m 250 blower
goin to freshen these up was wondering if adding super chillers to these would make that big of a difference.they are single carb type,with these blowers what horsepower could i expect? i spin them at 5000in the heat of summer to 5300rpm in spring. should i prop the boat to go 5500rpm.also these have around 90hrs should i freshen or add the coolers and wait one more year to freshen
Re: 509s w/ b&m 250 blower
Do a leak down test. If it shows OK, go another year. Put a chiller on, crank the boost back up to where it was without the chiller & take it easy on the drives.
t.t.t
Johnny,
I think I told you about an old set of motors I had but in case I did not here you go: 509ci 8:1 static superchillers dual holleys brodix heads They made 805 Hp at 6200 Rpm I turned them 6400 in the boat I pulled the boat yesterday so I will have those oil coolers etc in the next couple of weeks. Give me a call I still have my cam card from the 509's. |
| All times are GMT -5. The time now is 08:12 PM. |
