oil pan for 383
WOW!! Did a search on 383s.Alot of reading.I was wondering what kind of oil pans -windage tray set up is needed?Also what advantage is gained by useing hyd.roller cam vs std hyd cam?
Paul |
Re: oil pan for 383
When we talk about pans with stroker clearence, a 383, 3.75" stroke doesn't have major clearence issues for most pans so it shouldn't be a big concern, but just ask when you are ordering.
Hydraulic cams basically spin up faster then flat tappet cams. that is the difference you will notice when using one. These are very basic answers |
Re: oil pan for 383
I used one from champ. I think its champpans.com.. A marine pan with windage tray and scraper, 7 qts.
| All times are GMT -5. The time now is 08:21 PM. |
