6.2 L Mercruiser cam specs
Does anyone have the cam specs for the Mercruiser 6.2 L series engines?
Re: 6.2 L Mercruiser cam specs
Crane 104224
Lift: Intake @Cam 301 @Valve 452 All Lifts are based on zero lash and theoretical rocker arm ratios. Exhaust @ Cam 310 @Valve 465 Rocker Arm Ratio 1.50 Cam Timing: -- @--- Lift: Opens Closes ADV Duration Intake --- --- 270 ° Exhaust --- --- 276 ° Cam Timing: TAPPET @.050 Lift: Opens Closes Max Lift Duration Intake 0.0 BTDC 34.0 ABDC 107 214 ° Exhaust 47.0 BBDC (7.0) BTDC 117 220 ° This information is from bobl/FTM. Thanks goes to him. |
| All times are GMT -5. The time now is 08:46 PM. |
