540 Build up?
I could use some suggestions. I am about to take the next steo in building up my 540. The bottom end is complete and I have one season on it. Everything is fine but it is time to upgrade the heads and carb. Currently I have standard cast iron rect. port heads from my old 454, a dart midrise sigle plane intake and a Holley 800cfm carb. Cam is ISKY model RR-275/284. Hyd Roller. Adv. 275/[email protected] 228/238. .553"/.578", 108ICL, 114LSA. Currently have 9:1 compression with flat top forged pistons.
Max power is 575 at 5400rpm with max torque of 650 below 3700rpm. Torque is falling off after 3700rpm and is down to 560 at 5400rpm. The motor is in the boat and I don't want to pull it so please no cam suggestions for now. What heads would you recommend? What carb would you recommend? Would you suggest going to a higher ratio rocker to get a little extra lift with the same cam? The boat is a 24' eliminator daytona. I want to get good power while maintaining a good idle and low end torque. Thanks for your suggestions |
Re: 540 Build up?
I built a 540 last winter. Below is my combination and dyno results.
Dart Big "M" Block Callies dragon slayer crank Lunati Pro Mod rods 6.385" JE Pistons 9.23 final compression A.F.R. 315 cnc heads, Ferrea 2.25 intakes, 1.88 inconel exhaust Dart single plane oval port intake, gasket matched to heads Isky hydraulic roller intake .578 lift--- 238* @ .050 exhaust .608 lift---248* @ .050 114* lobe seperation Nickerson prepped 1050 dominator Wilson tapered 1" spacer RPM Horsepower Torque 3300 381 607 3400 394 609 3500 407 610 3600 416 608 3700 427 606 3800 438 606 3900 450 606 4000 464 610 4100 479 613 4200 503 629 4300 518 633 4400 539 643 4500 558 651 4600 575 657 4700 590 660 4800 603 659 4900 616 661 5000 627 658 5100 638 657 5200 648 654 5300 657 651 5400 665 646 5500 670 639 5600 672 630 5700 674 621 5800 678 613 5900 679 608 |
Re: 540 Build up?
Head, and cam combinations can be a pretty controversial subject. Actually, I kind of like the cam you have now for your cubic inches, and would NOT change it----but hey, that's just me as I tend to "errr" on the smaller side of things. :D You can go with something like a Holley 850cfm carb. Any good flowing aluminum aftermarket heads would help---there are several brands out there that would get you in the ball park, but I would say that AFR is one of the top flowing heads out there if you have the $$$ for them. An AFR 305cc head would give you a wider torque band, and would be a good choice for your 540 marine.
Here's some info you might be able to use in comparison. I use the 315cc AFR cnc ported heads on my natuarlly aspirated 565cid engines with a Dart single plane intake, and a 950cfm Holley. I suppose I could have went with some larger volume/cc sized heads like some AFR 335cc heads and I still would have been fine, but the smaller 315cc heads on my size CID engines are a real kick in the pants! |
Re: 540 Build up?
Thanks for the input. Kaama, I went through a few of your old posts and got alot of good information on the AFR heads. It looks like the AFR heads might give the best results. The 305cc heads should be a great improvement over the GM heads under 5000rpm. The 315's might add a few HP after 5000rpm but I'm most interested in cruise and short top end bursts. Would you upgrade to an 850 Holley or just stay with the 800 I already have? I can live without a mile or two on the top end and put the $$ into my other toys. Would I see any improvement with a higher ratio rocker setup?
Thanks |
Re: 540 Build up?
1 Attachment(s)
I also joined the 540 club back in 2004. I have 40 hours total on my motor in two seasons.
I short list of components (very much like Checkmate's). Dart Big M Block Callies Dragonslayer crank Lunati Pro Mod rods 9.2:1 CR AFR 305 CNC'd Chambers Merlin Single Plane with Nickerson 1050 Custom Comp Cam 236/240 @.050 .630/.635 lift 112 LSA Keith Eickert Exhaust withh GGB mufflers. All of this in a 1989 27' Activator with Bravo XR/ IMCO -2 Shortie. Runs 82.7 (GPS) at 5600 rpm with 26" Bravo (stock). |
Re: 540 Build up?
Originally Posted by vegas daytona
The 305cc heads should be a great improvement over the GM heads under 5000rpm. The 315's might add a few HP after 5000rpm but I'm most interested in cruise and short top end bursts. Would you upgrade to an 850 Holley or just stay with the 800 I already have? I can live without a mile or two on the top end and put the $$ into my other toys. Would I see any improvement with a higher ratio rocker setup? Thanks
Also, I need to clearify something here----the cam you have now is okay for the GM heads you now have, but too low of a lift, and a bit too wide on the I/E split if you were to use it with the AFR heads. A 305cc AFR head that flows real well to .600" lift doesn't need a wide I/E split cam like a GM head would. So, contrary to what I posted previously, I would definately go with a different cam profile more suited for the better flow characteristics of the AFR head. This where I believe a custom cam profile would be more beneficial vs just an "off the shelf" cam. "rmbuilder"/Bob would be a knowledgable cam tech guy to ask---his prices are fair/competitive. A custom cam is not that much more than a quality off the shelf cam. The cam is the brain, and is the final, most important part to consider with the heads you have selected. If you want to optimize the flow characteristics of the heads you are using then, proper cam selection is the key. That's why one cam doesn't fit all. Send Bob a PM, I am quite positive that he can explain it much better than most. Unless you have a ton of $$$ to spend on gas then I would assume that cruising is where you'll spend most of your time. If you plan on dyno testing your engine(s), then see if you can borrow a friend's 850 carb or even a 950cfm carb first to see what the difference would be compared to the 800 carb you now have, and if it would be worth buying. I would think you'd get better results out of a larger carb than an 800 for your application/cid. That's one reason why dyno testing an engine is a very beneficial tool to use to help narrow down all the variables there are or may be---and find problems or potential problems if you can afford it. |
Re: 540 Build up?
Just for clarification.
718 HP @ 5900 RPM 700 FT/LBS @ 5000 RPM I personally would liked to have seen the RPM peaks shifted down about 500 RPM. Cam is probably a little long on duration but when you have one shot to get it right and limited funds, you only have one cam ground. My engine builder (who is quite capable at performance builds) said we would have given up the peak numbers with less cam. In hindsight, that would have been okay. Even a mild 540 has enough power to break outdrives. I second the call to Rmbuilder. The man knows his stuff. Fortunately for me, we have become good friends. He has been in my boat (several times) and can confirm the performance attributes. |
Re: 540 Build up?
RLW : If you had to do it again what cam would you use
Re: 540 Build up?
I don't know much about cams.
I would let my Cam Guru come up with that information. Seriously, PM Rmbuilder. |
| All times are GMT -5. The time now is 11:26 PM. |
