-   -   Supercharging a 500 EFI (https://www.offshoreonly.com/forums/general-q/115195-supercharging-500-efi.html)
Bryan Rose 10-26-2005 04:50 PM
I have a 85 hour 500 EFI I want to get more power from, I have done a lot of reading and it seems the threads are started but always end up turning a different direction before they finish addressing the issue. I have looked into several methods of gaining power but it seems centrifigul superchargers end up getting the nod. So there are several companies out there that have a kit , Vortec, Procharger , R-tech just to name a few. Who has the most complete user friendly turn key Kit? I am at a loss here and would really rather build pwer N/A but it seems the efi is limiting my choices, so if you have a good recipe for 600 -650 HP NA on a 500 EFI let me know otherwise...........
who has the best kit as asked above.
Bryan
chuckels 10-26-2005 06:24 PM
Re: Supercharging a 500 EFI
I would have to say whipple :cool:
monstaaa 10-26-2005 06:32 PM
whipple has ,, lets just say less than desireable turn time. i would suggest pro charger or vortec.
4mulafastech 10-26-2005 06:51 PM
What do you mean by turn time?
t500hps 10-26-2005 07:11 PM
Ordre now and be ready for a nice spring run...in 2007! :eek:
Actually I don't know that, but I keep hearing they are way backed up.
Mudball 10-26-2005 07:17 PM
1 Attachment(s)
Whipple has apparently had a hard time delivering product.
I vote for a Whipple with a F.A.S.T. computer, running closed loop!!
Open loop sugs! I have a hard time believing that Merc even does that...
PM FTMBob for more details...
Here's his motor.. I love that motor! You even program it from a laptop while on the water for perfect everything, and it stays there with varying conditions!!
IMO, this is THE setup for a blower!!!
Kent
Dock Holiday 10-26-2005 07:59 PM
Contact Fred Cecil AKA "Too Old" at Trick Marine.
He is a dealer for Vortech and has some good information and good prices.
Personally I am leaning toward Vortech because of two boats that I know are running them with VERY good results.
Another thing is their kit is 100% COMPLETE!
Call Fred.
MnHowardCat 10-26-2005 09:31 PM
1 Attachment(s)
I jest saw a Whipple in the classifieds
I like my Whipple's
Fountainclimber 10-26-2005 09:51 PM
Mine ran great but I did go through the engine first.
http://www.offshoreonly.com/forums/s...hlight=vortech
TxHawk 10-26-2005 09:54 PM
3 Attachment(s)
We have had very good results using the vortech system, I wouldnt touch a procharger. 600-650 HP could be attained with very little boost. We have several boats running this setup making 700-950 HP with the vortech charger. All the setups have had no issues and truely been flawless. We are very impressed with the setup.
Matt
Derebery Performance
www.dpmpower.us
Outdrive1 10-26-2005 11:52 PM
1 Attachment(s)
I'd recommend the Vortech too. I have about 220 hours on my motor with good success. I think the key is set up though. Don't think you can just bolt one up, you need the complete fuel system, injectors, pump and regulator as well as the ECM reprogrammed. I had AZSM do mine. I'm sure there are others that can do it as well but I was told AZSM wrote the programs for Vortech. They did mine at the lake on the fly over 4 days. I don't know if other companies would put that much time into making it right.
Outdrive1 10-26-2005 11:53 PM
BTW, what drive are you running? I can tell you from experience that stock Bravo 1 won't last too long....... :evilb: :evilb:
TxHawk 10-27-2005 07:41 AM
Nice looking setup. We will only install this system if the customer agrees to let us pull the engine and dyno tune. Like you said, it is not a "bolt on" system, there are a lot of other key factors involved in making the Vortech system flawless.
Outdrive1 10-27-2005 10:45 AM
It really is important to run the motor and set the fuel mixture. If you don't have a dyno or a way to run it on the fly you're just guessing. All it takes is lean for a second and you'll be pulling the motor anyways, might as well do it right the first time. What gas do you guys recommend after installation? I was running 93 but sometimes above 5000rpm when it's hot here (110 plus) my knock sensor shuts the motor down on me. I switched to A/v gas and haven't had any problems since.
TxHawk 10-27-2005 11:28 AM
We run on 93 for most applications. Some of our 540ci Vortech S/C'd engines that like to crank up the boost will run 114.
Bryan Rose 10-27-2005 05:11 PM
Thanks for all the help on this...As I stated I am only looking for 600-650 ponies and would like to keep the boost down to make the drive live a little longer. I was also hoping to run 89 octane fuel as well, hopefully keeping the boost down will let me do that. The dyno thing is no problem I have a dyno 20 minutes from my house. Now that I think about it 650 ponies would be just about right, for my rig and would push me into the 80's easily. Then it would be time to upgrade the drive to keep things safe. It has a bravo I now ....what is the best alternative for this? would like to get a 2" shorty.
Bryan
Outdrive1 10-27-2005 06:00 PM
Bryan
A shorty isn't going to help out, your upper will probably blow the floor out of it first. You really need an XR or have someone build you drive like Mr Gadgets or Max Machine Worx, Imco, Teague etc.. You could run the drive and baby it as long as you can. It could hold up forever but it's doubtful. Better get some external steering too while you are at it.
As far as 89, keep your motor stock if that's an issue. You wont be able to run it, no point in taking a chance on detonation to save 5 bucks at the pump. Premium only in your blower motor, even a naturally aspirated motor that's only 500 ci making 650 hp won't run on 89. It's just not going to happen, or it could happen but you'll be putting new pistons or valves in it regularly.
Bryan Rose 10-27-2005 06:55 PM
A shorty isn't going to help out, your upper will probably blow the floor out of it first. You really need an XR or have someone build you drive like Mr Gaskets or Max Machine Worx, Imco, Teague etc.. You could run the drive and baby it as long as you can. It could hold up forever but it's doubtful. Better get some external steering too while you are at it.
OK then ....that settles that.....Iguess I will be running 93 in it then. As far as the steering goes I am in the process of puting a system together, I have aquired a new Capilano 1250 helm and am working on the rest, I am going full hydraulic helm to dual rams, thought about the add on but thought that going full now would save me a headache in the future, for the drive I am considering many options but when I do it I am going to go 2" shorter....any suggestions? for this stuff mentioned above.
Bryan
offshoredrillin 10-27-2005 08:48 PM
Bryan
Bryan,
I'm not trying to rain on the SC parade, but , why not just have the motors redone and keep the reliablility of the EFI and natural aspiration. JC perf is taking the 500 efi's in my tiger and putting them at 625. from mercs standards the motors are about 505-525 from the factory. cam headwork and comp prog changes 600-625 is easily attainable. Just food for thought...Rob
800XCR 10-27-2005 09:12 PM
Not to rain on the N/A parade or anyones abilities, but keeping the 500 efi system in conjunction with E-top headers will NOT result in an easy 600-625 HP on pump fuel without supercharging it regardless of what you do to it.
I have seen a few of the so called dyno sheets showing it, but for some unknown reason, the boats never showed the benefit of a 100+ hp gain.
The intake won't support the airflow required to make that kind of hp without it being forced and the headers certainly won't. Especially with only 502/509 cubic inches. Call CMI and ask them.
Good Luck.
INDY27 10-28-2005 09:57 PM
Bryan,
I have had a Stage II Procharger on my boat for four years with no issues related to the Procharger, Procharger, whipple, vortech...all the kits are good but SETUP is the key! Get in touch with Mark Boos at Precision Marine, he is one of the most knowledgable people around.
ZXXX Donzi 10-28-2005 10:09 PM
Who did your installation? I am playing with the idea down here in Eufaula.
TxHawk 10-29-2005 08:49 AM
Good Luck.
Not true, I have seen over 670HP from a 540ci engine on the 500EFI platform. That reused the intake and e-top headers.
INDY27 10-29-2005 10:12 AM
I did the install with the help of a very knowledgable freind of mine and had Precision Marine remap my ECU. There is really not that much to the install on a EFI motor, just make sure to get the ecu remapped and that you understand how to put the engine in base timing mode and its a peice of cake. :chimp:
ZXXX Donzi 10-29-2005 11:13 AM
Good deal. I will call Precision Marine. I got someone that has done a few few down here but does not reprogram.
800XCR 10-29-2005 04:36 PM
Excal.....I'm not buying. However, I am willing to learn as most of us are. Please post engine specifics including head and cam info along with a dyno sheet with a/f ratios and egts. How much faster did the boat go when installed? Thanks and look forward to the education.
