Re: Head advice on BBC
Call JimV and talk to him. He will have great info for you and maybe a set of used heads from someone who upgrades.
Originally Posted by jeffswav
My wife shot down the new heads. I need to keep my cost down.
Jeff ITS BETTER TO ASK FOR FORGIVENESS THAN ASKING FOR PERMISSION :evilb: :evilb: :evilb: Go for it and let us know the power results :rolleyes: |
...my machinist has a set of 3993820's and 353049's. Thanks,
Jeff Anyway, you'll be much farther ahead with the larger 049 oval port heads vs the peanut ports. Also, if I remember correctly "JimV' told me that the 049's don't flow much past .550" lift---even after porting so, you obviously don't want to cam it much beyond that. |
Originally Posted by KAAMA
Jeff, I'd snatch up those "049" castings from your machinist!!! I didn't originally see this when you posted it, but the 353049 castings from GM (we call them "049" castings) are an excellent head for your engine.
I do know Gen VI heads work on Gen IV blocks. Gen V blocks have real big core holes at the head surface. I'm thinking that combo will leak... |
Originally Posted by Pat McPherson
Will Gen IV head castings work on a Gen V engine block???
Pat, I really don't know! I know you brought that up before and I completely forgot---good point!!! My bad. Are you sure there isn't a gasket that will allow them to mate without leaks? I'm going to ask around.
When GM retooled for the Gen VI block and head castings they fixed a lot of the incompatibility issues that exist with the Gen V castings. The after-market companies have designed their heads to work on all generations of blocks. It sounds like we have a good topic to start another thread... :cool: |
Just wanted to keep you guys updated. My machine shop had a set of 820's from a 71 454. I am having new hardened seats installed on the exhaust, severe duty valves, 2.19 & 1.88 and I am using the guild plates, rockers and studs from my other heads. I am going to do some port & bowl work and I should be ready to go. As far as the Mark IV Gen V compatibility goes, I have been told a Mark IV head will fit a Gen V block with Gen V gaskets. A Gen V head will not fit on a Mark IV. Should have about $850 in the heads with me doing the port work. I will let you guys know how it turns out.
Thanks, Jeff |
Originally Posted by hondatv
amer3 : can I get a copy of the flow chart? I'm thinking about buying a set for my 540.
After doing more reserch I am probably going to find a set of L29 vortec castings, I already have rockers, studs, valve guides and springs. All I need are the castings. If anyone has a good deal on a set let me know. I am located in the St Louis MO area.
Thanks, Jeff |
| All times are GMT -5. The time now is 10:54 PM. |
