Head advice on BBC >
Head advice on BBC
Head advice on BBC
Old 11-02-2005 | 06:15 AM
  #41
Default Re: Head advice on BBC
Call JimV and talk to him. He will have great info for you and maybe a set of used heads from someone who upgrades.
cobra marty is offline
Old 11-02-2005 | 08:51 AM
  #42
GoCiggie31's Avatar
From: Where the water meets the oaks 'n Pines in the Sierra Nevada's of NorCal
Originally Posted by jeffswav
My wife shot down the new heads. I need to keep my cost down.
Jeff
I'm with jjones boating season is way too short to worry about $ spent on the boat
ITS BETTER TO ASK FOR FORGIVENESS THAN ASKING FOR PERMISSION
Go for it and let us know the power results
GoCiggie31 is offline
Old 11-05-2005 | 10:15 AM
  #43
KAAMA's Avatar
...my machinist has a set of 3993820's and 353049's. Thanks,
Jeff
Jeff, I'd snatch up those "049" castings from your machinist!!! I didn't originally see this when you posted it, but the 353049 castings from GM (we call them "049" castings) are an excellent head for your engine. They have the larger oval ports than the "peanut ports" you have now, but you'd still need to do the bowl/pocket porting work with them. You can even install larger valves as we used to do back in the 1980's. However, as with any stainless steel valve you will still need to at least install hardend valve seats---at least on the exhaust side otherwise they will sink---we went through all of that back in the day.
Anyway, you'll be much farther ahead with the larger 049 oval port heads vs the peanut ports. Also, if I remember correctly "JimV' told me that the 049's don't flow much past .550" lift---even after porting so, you obviously don't want to cam it much beyond that.
KAAMA is offline
Old 11-05-2005 | 12:10 PM
  #44
Pat McPherson's Avatar
Will Gen IV head castings work on a Gen V engine block???
I do know Gen VI heads work on Gen IV blocks. Gen V blocks have real big core holes at the head surface. I'm thinking that combo will leak...
Patrick
Pat McPherson is offline
Old 11-05-2005 | 01:52 PM
  #45
KAAMA's Avatar
Pat, I really don't know! I know you brought that up before and I completely forgot---good point!!! My bad. Are you sure there isn't a gasket that will allow them to mate without leaks? I'm going to ask around.
KAAMA is offline
Old 11-05-2005 | 06:34 PM
  #46
I have heard of special gaskets for the Gen V blocks but I have no experience using them.
When GM retooled for the Gen VI block and head castings they fixed a lot of the incompatibility issues that exist with the Gen V castings. The after-market companies have designed their heads to work on all generations of blocks.
It sounds like we have a good topic to start another thread...
Patrick
Old 11-07-2005 | 06:36 PM
  #47
Just wanted to keep you guys updated. My machine shop had a set of 820's from a 71 454. I am having new hardened seats installed on the exhaust, severe duty valves, 2.19 & 1.88 and I am using the guild plates, rockers and studs from my other heads. I am going to do some port & bowl work and I should be ready to go. As far as the Mark IV Gen V compatibility goes, I have been told a Mark IV head will fit a Gen V block with Gen V gaskets. A Gen V head will not fit on a Mark IV. Should have about $850 in the heads with me doing the port work. I will let you guys know how it turns out.
Thanks,
Jeff
jeffswav is offline
Old 11-07-2005 | 06:46 PM
  #48
Originally Posted by hondatv
amer3 : can I get a copy of the flow chart? I'm thinking about buying a set for my 540.
email me [email protected] and i will send it to you.
amer3 is offline
Old 11-07-2005 | 06:52 PM
  #49
After doing more reserch I am probably going to find a set of L29 vortec castings, I already have rockers, studs, valve guides and springs. All I need are the castings. If anyone has a good deal on a set let me know. I am located in the St Louis MO area.
Thanks,
Jeff
call me im in st charles mo 314 265 3876
amer3 is offline
Sick Stinger
01-31-2007 01:58 PM
khadley
7
12-29-2005 11:17 AM
phughes69
4
09-29-2004 07:08 PM
Panic Button
8
09-21-2004 01:02 PM
fred
11
09-22-2003 12:29 AM
