why/how did this happen?
2 Attachment(s)
last nice weekend of the summer and 1/2 hour out, this happens :(
can this be fixed and if so how much? case has crack/cut on both sides. what causes this to happen? could i have done something to prevent it? thanks! |
Re: why/how did this happen?
I doubt that case can be repaired.. Didnt that lower nut have lock tabs bent behind it?
300 pro maxs |
ITS DONE, with the hole in the side cheapest fix is just to replace it !!!
i replaced a lower on my 2003 300x...left hand counter rotation 1.62:1 20" sportsmaster was a little over $4000.00 Steve where are you located ?
Originally Posted by hillbilly24
It's not very clear in the picture but from what I can see it doesn't have a locking tab ring in it. If this is the case and you have hed someone go through the lower I would take it to them exactley as it is now, don't even take the prop off.
bernie, i live in the kansas city area. welding it up wont work? i dont want to spend a bunch of money trying that if its a doubtful situation? |
I have two housings from 250 xl merc racing Id have to check for cross over ect
Originally Posted by Steve_H
just bought the boat a few weeks ago. was going to have the lowers serviced before putting it to bed for the winter.
| All times are GMT -5. The time now is 09:09 AM. |
