More Power
I Have 525sc's In My 38 And Want More Power,I Have Already Installed Chillers And Pulleys And Do Have More Power Than Stock But Now I Want More!cams,Heads Etc Or Do I Scrap These Engines And Start From Scratch!Whats The Best Way?How Much More Will The Right Cams And Heads Change The Engines Or Are These Things Maxed Out Now? Thanks!
Re: More Power
You can probably get some ideas from guys on here, but I would suggest that you would still/eventually PM "rmbuilder"...he has the knowledge, experience, and integrity to help you get set up with the right head/cam combination for the cubic inch size of your engines, type of application, etc. He has helped me with my combination, and several others here.
Re: More Power
KAAMA has a good plan, I may add that you have a good induction system you may want to add some stroke to the engines and gain some CID. That extra .250" of arm does wonders.
Chris |
Re: More Power
At some point the blowers themselves become the bottle neck. Will 250 blowers fit the intercoolers you bought?
Re: More Power
1 Attachment(s)
im not sure if the 250 will fit the coolers,i will find out today,thanks!heres a pic of what i have now
Re: More Power
It is my understanding that increasing the cubes with the same blower will drop the current max boost some since we are now feeding a larger volume. I would want to know if you would still gain horsepower with the lower boost if you keep the present blower.
Re: More Power
I'd say scrap the old induction and drop on some 8-71s at around 7-7.5psi with some roller cams....
Come to think of it, MSD ignition and spinning it at 5600rpm should help too. Forget the rod deal, a .250 longer rod may give you 5-7hp. |
Re: More Power
so i guess get rid of the induction from intake up?what about getting new heads or flowing out mine,which way is better?
Re: More Power
What did you find out about a larger blower fitting on your present intake? |
Re: More Power
I wouldn't worry about the heads...good enough for the 454CID.
I might even take back the cam swap idea....to much work and $ for a 30-40hp gain. The 8-71's should do it. |
| All times are GMT -5. The time now is 04:36 AM. |
