What exactly is "reversion?
I have black rubber external flaps on my exhaust. I was thinking of switching to an angle cut tip exhaust tip. Everybody keeps saying watch for "reversion"
Please help. Thanks |
Re: What exactly is "reversion?
The flaps help keep splashing water out of the exhaust pipes. Usually at slow speeds or when in nuetral.
reversion is when water reverses and come back into the motor through the exaust usually when you come off plane. the rubber flaps help prevent this as do the flappers in the pipe,
Hmmm, well, reversion is really when the water in your exhaust system ( in a wet exhaust system) is sucked back into the cylinder through the exhaust valve during valve overlap at idle. Valve overlap is when the exhaust valve and intake valve are open at the same time. The flapper at the end of the exhaust pipe doesnt have anything to do with it. It does help stop surges of water from getting in your engine when it is off or if it quits while you are running and that big surge of water comes rushing forward.
formula is correct except that just water from the exhaust wont come back unless there is an abundance of it hence coming back in from the exhaust through hulls
Do you then think that switching to the angle tip and thus loosing the external flapper would be OK??????
Sorry, but Formula is RIGHT! Unless you are running a strictly dry stack exhaust, there is always water in the pipe and "outside abundance" has little or nothing to do with REVERSION. Now, to the point; If you are changing to an angled style exhaust tip, I suggest that you purchase ones that include the internal flapper. Your situation will be as good or better than it is now. --- Jer
You can purchase angle tips with internal flappers, then you have no worries. The flaps will protect you from the potential water surge that you get when coming off plane too quickly. But as formula said, reversion is from excessive cam overlap, and the water exiting your engine getting sucked back into the exhaust at the point where the water mixes with the exhaust gases. Thats why they sell long risers, and dry pipe systems.:)
sound like internal flapper is the way to go.
Thanks |
Originally Posted by Liberator21
Thats why they sell dry pipe systems.:)
http://www.h20htr.com/videos/neilsboat.wmv |
well said hillbilly !!!
But , its just semantics. Im surprised you dont know that. |
I kinda think f31 is correct here as far as actual terminolgy. Ingestion appears to be what G Man is inquiring about, not reversion.
Nit picking, eh? :p |
Two terms, reversion and ingestion, two different things.
Oh wait, thats indegestion :D |
Thanks |
Thanks to all!!
Formula is right. Reversion is an engine issue, and flaps won't fix that. Ingestion is a different issue, and that what flaps are for. Like jpclear said, you've got the answer you need and then some. Put on the flaps and go boating!!! |
I have found that cutting down the water to the pipes, running some overboard, and staying above 900 rpm helps alot. Real deal is adding a blower and reversion seems to go away :D
Will internal flaps quiet the exhaust at all. My internal flaps are gone..
not when open !!!!!
not when open !!!!!
Send me your email address, and I will send my new reversion page from our new website (not up yet).
im sorry was thinking about silent choice
| All times are GMT -5. The time now is 02:12 AM. |
