-   -   Stiff shifters now stuck in Reverse (https://www.offshoreonly.com/forums/general-q/115894-stiff-shifters-now-stuck-reverse.html)
GoCiggie31 11-06-2005 11:30 PM
ever since I purchased my 1990 cig my shifters have been very stiff to operate, like it was dragging. Sometimes it would have so much DRAG that it would be hard to go into gear. Well, today, my port side gear shift stuck in reverse and it feels like if I push any harder, it would bend/break the controls (gaffrig I think) even to try to get it to neutral.
What is the best way to identify the problem? .Could this be shift cables and how difficult is it to replace the cables? Is there one continous cable per drive?
Thank in advance for your help
hillbilly24 11-06-2005 11:48 PM
Re: Stiff shifters now stuck in Reverse
do you have TRS drives or Bravos. If you have Bravos there is one cable from the shifter to the shift bracket that i ussualy mounted on the engine but sometime on the transom and then another from the bracket to the drive. If you have TRS drives there is just one cable to the trans. If you have Bravos the first thing you want to do is disconect the cable from the shifters to the shift bracket, if it shifts easily then you have narrowed it to either the cable or the shifter, probably the cable but you never know. The engine will have to be runing to shift smoothly if at all. If it is still stiff at the shift bracket then the drive needs to come off. If you find water in the shift cavity of the belhousing or drive you need to change the lower shift cable and probably the shift link in the drive. If the lower cable is clean and dry and moves freely with the drive off then it's in the shift linkage in the drive or the shift adjustment was way off. Shift adjustment is checked and asjusted with the drive off on Bravo models. Ther are a couple merc tools you will need to do it but they are pretty cheap. If the shift adjustment checks out then you need to pull the back cap off the drive and see whats going on with the shift link and yoke.
GOODT 11-07-2005 06:41 AM
alot of times if you shut the motor off while in gear bravos will stick !!!!to get it out have someone jump the slave soliniod while someone shifts it .....
note: do not turn the key on !!!!!!!!
GoCiggie31 11-07-2005 07:49 AM
thanks guys, sorry for the lack of details.
It is a Bravo 1 setup. When I put it into reverse while running I could not get it out of gear so I had to shut down the engine while still in gear and there it sits.
I have been thinking that since it was a salt water boat and the shifters were stiff eversince I purchased the boat, then cables will probably need to be changed and no better time than late fall and winter.
Additionally, maybe this is the time to pull the drives/ replace the cables and also swap the drives to facilitate inboard prop rotation.
GOODT 11-07-2005 08:51 AM
you dont need swap the drive to change rotation on bravo, the rotation is controled at the shifter!!!! hard to shift on a bravo could be the cables or the shift fork in the drive merc had problems with them several years ago
GoCiggie31 11-07-2005 05:47 PM
GoodT,
regarding drive rotation, what I am understanding is that reverse can be forward and just swap the prop? So the drive doesn't care which way it rotates-cool! Would I swap the cable at the helm?
Hillbilly and GoodT,
Thanks and I will pull cables to isolate problem-
Another question, should the shifters be as smooth as throttle levers/efforts.
My prior boat was zero efforts on an alpha drive and it was way smooth and less effort. Do Bravo set ups have much more drag.
GOODT 11-07-2005 06:39 PM
depends on the shifter but for the most part yes. as for bravos they shift smoother then alphas but only like to shift while running
yes, bravos dont care what direction they spin
hillbilly24 11-07-2005 06:56 PM
If you want to swap rotation just switch props and switch the cables to the opposite throw of the shifter, it has two to facilitate this. The only thing you want to do is add billet top caps, the drive that runs counter rotation will put al of the thrust on the op cap when in foward instead of the housing this makes the counter rotater a little weaker but can be fixed with a beefy top cap.
GoCiggie31 11-07-2005 08:19 PM
Guys,
great info
thanks :D :D :D
bulova1997 04-29-2012 07:49 PM
89 baja 235 force bravo 1 outdrive stuck in reverse
my bravo one out drive was shifting normal and when i came back from the lake i put it in reverse while pulling up to my slip in the marina when i pushed my shifter forward it would stay in neutral and i kept pumping it from forward to neutral and now it stays stuck in reverse completly, out drive cable moves back and forth freely but doesnt take the boat out of reverse
Griff 04-29-2012 10:46 PM
More than likely the shift linkage assembly and detent inside the back cover of the drive needs to be replaced.
MnFastBoat 05-02-2012 12:39 PM
Exactly my thoughts and what I was going to say :)
Been here done that.
Pull the back cap off and inspect the detent ball,
All I did was clean it all up and regreased. Local dealer had a 10 day back order on them so this was just to get me by, three or four years later I still have the replacements in the garage shelf :)
matthewr 05-02-2012 01:11 PM
+1
Done the same with mine this year. You would darn near break your hand to shift it. I pulled the back plate off along with dentent ball and shifting linkage. I took a round grinding stone on a die grinder and smoothed where the dentent ball rides on the recessed area of the shifting linkage. Greased it up and works like butter now.
