Overlaod
Just Bought New A Chevy Dmax,big Time Sag When Hooked Up,alot More Than My Ford!whats The Best Way To Go,overlaod Springs,airbags,helwig?? Whats The Best Way To Go??
Re: Overlaod
Does Any Body Tow?
Re: Overlaod
Sag in what? The frame??
Re: Overlaod
I'm guessing you got the 3/4 ton truck as the duallys have the overload spring on top of the regular springs. You can try and install those if you want a factory look. Or if it were me i would install airbags and go with a weight distribution hitch...
Re: Overlaod
Airbags-- Totally adjustable for any weight and when you're empty, let the air out and it rides the same as stock. Be careful if you are thinking of adding springs. that will change the ride all the time.
Re: Overlaod
thanks,im going with the airbags!
Re: Overlaod
Justin
The Reno twins at Hitchcrafters in CM pimped my F550 with the in cab air inflation system. Very fair price and prompt. Hugh |
Re: Overlaod
I have Firestone Ride Rites on My 99 Chevy Dually,get the on board air compressor it is the Shiznit!
| All times are GMT -5. The time now is 02:59 PM. |
