Re: jesel shaft rocker system ?????experiences
Originally Posted by checkmate454mag
Smitty,
I am running the same lifters in my NA 540. I have an Isky hydraulic roller, Isly silicon springs with AFR 315 CNC heads. I set the spring pressure to 140 lbs. as per Isky's recommendation. I understand your reasons for running 190 lbs on the seat. I just never heard of that much pressure on a hydraulic lifter. That is good news to me. It gives me confidence in the Morel lifters. Vinny |
Smitty,
I am propped to run at 5700 rpm. I dont remember off hand what my open pressure is. When I get home, I can look it up. |
An alternative source is DRERACING.com.They manufacture shaft rockers.However, especially nice, they will fit the stands to your heads.And if they have your cam and head gasket thickness,help with the push rod diameter,length and fit.In other words;mock up your heads to fit the stands and rockers by using their block(s) and adjustable push rods.They may also suggest 7/16 diameter .120 wall push rods.Some feel the bigger push rod has less deflection,less vibration and serves to reduce roller skating.
I would like to thank all you guys for the awsome information,i can now sit down with my engine builder and make an inteligent decision.
mv,
are we building for the 35? who's your engine guy, my 350magmpis need another 100hp, have a great holiday season and tell the movie star mike and kitty say hi |
| All times are GMT -5. The time now is 01:43 PM. |
