Hydraulic Outdrive Lift / Stand
There was a company advertising in the classifieds a few weeks back that had a real nice hydraulic lift for outdrives that made it real easy for one person to remove and install an outdrive.
Does anyone know who this was or how I would get in touch with them to buy one. Thank you |
Re: Hydraulic Outdrive Lift / Stand
1 Attachment(s)
2 Attachment(s)
There is one that a local company in kawkalin,Mi is making that looks like a adapted engine stand that lifts the drive quite high for 700 or 800$ . This is the one I use(a yardarm) and it works great,but it doesn't lift the drive as high as the ones that your talking about,Smitty
Thanks guys.
Those look very nice and I plan to look into them. The guy I saw here on OSO was in Michigan. My concern is height. The boat sits on a Myco trailer that puts it up higher then most. Although I'm sure you could modify the arms if needed for the extra height. Dock |
You could allways use a cheaper one and if hight is a problem just use a palet and a pice of plywood to gain hight.For me the problem is not the removel but the install is where the takeing you time is my main goal. My .02 :D
I always lift the front of the trailer. That brings the back down to a workable height.
??? 40 foot long triple axle trailer. That ain't going to work, plus you would then have the bolt on swim plaform in the way if you could do that. I have pulled drives many times by myself, just cannot get them back on without help. I called Yardarm and they are very nice people. I gave them or order, if you have a business they will give you an extra 10% off which brings it under $700.00. But after we completed the order, they then told me they could not ship for 8 weeks. Still looking for the company in Michigan if anyone has their name. Thank you. |
If you have access to a forklift they work very well for installing drives. Just put the blades real close together and slide them inbetween the upper and lower housing. Wrap the ends on the blades so you don't scratch your drive up. Once you get close the drive will slide back and forth on the blades and you can put the drive shaft into the bearing and push the drive the rest of the way on. It's not too complicated by yourself with a forklift.
2 Attachment(s)
Originally Posted by articfriends
(Post 1542336)
Have more picture with some spec ?? ....why i don`t find this thread before :rolleyes: ...cause right now i look to made one for two of my friend ...and realy like your idea Thank`s in advance |
We bought a motor cycle jack and welded a stand to the top of it to hold a drive. Roll it right up to the back of the boat and jack it as needed.....PERFECT!!! (I think the jack was less than $100 at Northern Tool)
Local guys around here have the Yard Arm products and love them.
Sears sells a quad lift for 69.00 and I just clamped a drive stand to it and it works perfect.
Nordic95 |
Originally Posted by 25 hors la loi
(Post 2098834)
Originally Posted by nordic95
(Post 2098956)
Nordic95 Ill have to try that:drink: My B max's are heavy |
I've used and engine hoist with a small cable loop many times for alphas, and I've also used the quadrunner jack with a homemade outdrive stand bolted to it. Either one works as well as the other, and cheap too, if you already have them hangin' around the garage anyway.
This one looks great:
http://www.woodyeng.com/ I haven't got one myself though. But I am considering it. |
That does look nice but A) dont see an angle adjustment and B) dont see a way to adjust angle, which will make it a real apain tohang the drive...canstill do if you pry the bell housing up but the yard arm has the adjustment so y make life harder then it has to be ????
| All times are GMT -5. The time now is 09:37 PM. |
