-   -   MEFI 3 or 4??? (https://www.offshoreonly.com/forums/general-q/118152-mefi-3-4-a.html)
East Coast B 12-10-2005 06:49 AM
MEFI 3 or 4???
Looking at a Mercury part # 861721T2 ecu, with a label ECB4 from a 1999 454mag, is this a Mefi 4?
I've done some searching here on OSO and I see that the recommendation is to go with a Mefi 4.
800XCR 12-10-2005 07:15 AM
Re: MEFI 3 or 4???
It is a mefi 3. I think I know someone that has one available if you are looking for one.
US1 Fountain 12-10-2005 08:57 AM
Re: MEFI 3 or 4???
Are you looking to upgrade or just replace? The ECB4 is the programing code.
East Coast B 12-10-2005 09:44 AM
Re: MEFI 3 or 4???
I've got 94 carb 454's right now and looking at complete mpi setup someone took off a 99 454 mag. Again, I think everyone says to go with the mefi 4, so want to be sure I know what I would be buying.
Dave_N 12-10-2005 10:04 AM
Re: MEFI 3 or 4???
Mercruiser never used MEFI 4. They went from MEFI 3 to ECM/PCM555.
Dave
Linster 12-10-2005 02:55 PM
Re: MEFI 3 or 4???
The MEFI 1 has the connections on the small sides of the computer, 180 degrees apart. The MEFI 3 has both plugs facing the same direction on the same wide surface. I am not aware of them using the 2. The 4 as stated above was never used. There is a plug that Merc has came up with to connect to a MEFI4. I hear Merc has no more 3's and are selling 4's as replacements.
East Coast B 12-10-2005 03:45 PM
Re: MEFI 3 or 4???
Looks like it's a mefi 3. Thanks for the descriptions!
Intake Manifold; Intake Plenum ;Injectors ,Throttle Body Assembly, ecu, wiring harness and I'll need an electric fuel pump. What else do I need?
Sending units of any kind?
TylerCrockett 12-10-2005 06:01 PM
Re: MEFI 3 or 4???
You will need a coolant sensor, Knock sensor, and the intake air temp sensor. We have a bunch of take off parts around if you need them.
East Coast B 12-11-2005 06:08 AM
Re: MEFI 3 or 4???
Is there any difference in the main plug on the wiring harness for the 99 compared to my 94 setup??? Or will it plug right in??
