-   -   Sportmaster questions, leave in fresh water? (https://www.offshoreonly.com/forums/general-q/118220-sportmaster-questions-leave-fresh-water.html)
IRONMAN 12-11-2005 12:39 PM
What is the finish on the sportmaster lower? Can they be left in fresh water? will one bolt to a std. X upper? Thanks, Chris
GOODT 12-11-2005 01:05 PM
Re: Sportmaster questions, leave in fresh water?
1 Attachment(s)
wouldnt leave in water for the most part they are bare alum.
as for bolting to a stock x drive they will but why only as strong as the weakest link, in this case it would be the upper gears.....
audacity 12-11-2005 01:48 PM
the gear change is done on the upper of a x and done in the lower of the sportmaster/xr.
marinetrans 12-11-2005 02:08 PM
Use Merc's magnesium zincs in fresh wawa.
Marginmn 12-12-2005 03:37 PM
I'm not sure about the -2 sportmaster but if you are trying to bolt a standard length sportmaster lower to a XR upper then you will need longer studs than the normal XR lowers use. I have a set of sportmaster XR's and when I changed the lowers to -2 imco shorties the studs were too long.
