Drive Shaving
Does anyone know what shavings on the outdrive fill screw are a sign of? I was changing my Gear Fluid this weekend on a Bravo1 and noticed some shavings on the fill screw Plug. I'm thinking it's a bearing or worse shaft problems. Any Ideas?
I would like to fix it myself before bringing it in to the shop, but don't want to get in over my head either... |
Re: Drive Shaving
shaft, gear, bearings...sure, could be any one or all of the above...seen it all...chances are it gear. building drives requires both specialized tools and know how.
where do you live? |
Re: Drive Shaving
well it depends if this is the first time you have changed your drive oil alittle metal is normal a small amount is normal between changes but if it is a big glob of metal or if the oil looks or smells burnt you may have issues, the gears mesh and some metal gets ground off also bearings can wear shafts usually just bend or break look at the oil dump in a rag or paper towel look for glitter if present take drive apart ( have it taken appart by a qualified mechanic)
Re: Drive Shaving
1 Attachment(s)
real simple answer if you have shavings then you have some problems, as stated above you need to have someone dissaseble, clean and inspect the unit to see what the damage is and what caused it...
no offence but I have had more customers then I care to think about bring me drives in boxes and all butchered up and say to me well I thought I could do it..... in most cases unless you have the proper tools and equipment and training you are better off just walking away because if you do mess somthing up it can get VERY expensive |
Re: Drive Shaving
I just bought the boat so this is the first time changing it. It has a round 500hrs on twin 502's with the Bravo1's The fluid is clean, blue/black looks and smells fresh except for the shavings. It is very little, almost like the screw is magnatised. Didn't notice any problems during seatrial, but you never know...
Do you think by just changing the fluid and running it i'll be ok? |
Re: Drive Shaving
your on borrowed time at this point...the screw is a mag.
take the top cap and back cap off...have a look. |
Re: Drive Shaving
Take the shavings and rub them between your finger and thunb. If its just like ink and leaves a mark but you can't feel anything then it's ok. If you can feel lumps or slivers then something is coming apart.
Re: Drive Shaving
Re: Drive Shaving
Re: Drive Shaving
| All times are GMT -5. The time now is 04:23 AM. |
