-   -   How much (or just how) to change a bad lifter? (https://www.offshoreonly.com/forums/general-q/118408-how-much-just-how-change-bad-lifter.html)
dockrocker 12-14-2005 09:35 AM
The patient: 1996 454 LX MPI (330 hp)
The symptoms: moderate 'ticking' sound that increases with engine speed. No discernable impact on performance. No excessive oil consumption. Compression test is good on all 8 cylinders.
The diagnosis: I'm thinking failed lifter rather than rod knock (I hope).
The question: Not being an engine surgeon, I talked to my regular (and respected) mechanic. He says to change out a bad lifter it would be something like $800 bucks. After I **** my pants, I thought I'd see if this is reasonable or if there is some way to 1) verify that it is a lifter and 2) fix it for less than the monthly gas bill for the boat!
Thanks in advance!
Wobble 12-14-2005 09:57 AM
Re: How much (or just how) to change a bad lifter?
It may be the lifter, in which case you have to remove the intake, valve covers, back off the pushrods and replace the lifter/lifters. Not that big a deal.
However on my buddies BBC the noise turned out to be a badly worn valve guide. Which eventualy dropped the valve and trashed the motor.
I hope it's the lifter.
Pat McPherson 12-14-2005 10:01 AM
If you are sure that it is lifter noise.
A set of GM roller lifters is about $250.
I don't know how to find which 1 would be bad.
The gastkets are about $100.
So if you think you can do the job yourself, you'll save some $$...
formula31 12-14-2005 10:11 AM
I would be more inclined to look at the rockers. If you use a long screwdriver to your ear (or stethescope) and touch it at places along the valve cover you should be able to find where it is. Then remove the valve cover (usually have to move or remove the exhaust manifold). You may just have one loose. It can be worse depending on the reason why it was loose but you might get lucky.
JasonSmith 12-14-2005 10:45 AM
Been there @ 5500 RPM when I dropped a valve. I too thought it was a lifter, then thought it was a rocker, then thought it was a exhaust manifold leak, then found out it was a bad valve.
If you can reach it, you can use a magnet retriever and take the lifter out by removing the valve cover if you know which one it is. You will have to fish it out through one of the oil galley holes in the head.
To say the least I would just use the bad lifter as an "Wife excuse" to take the motor out and upgrade performance.
"Well honey, it just has to be done right, and since it is taken apart anyway......."
dockrocker 12-14-2005 01:09 PM
Unfortunatley, there's not much horsepower to be found in these motors, at least economically. And I don't want to dump money in the other motor - the joys of twins.
To my ear, it sounds like the ticking is coming from the valley under the intake, rather than from under one of the valve covers. Guess I'll take another look at it when spring rolls around (I can't reach the boat right now, it's in rack storage).
birdog 12-14-2005 01:22 PM
Do the screwdriver trick...Works real well. Good luck on it just being a lifter !
Gary Anderson 12-14-2005 01:48 PM
I expect they're changing all the lifters.
To pull the intake, change all lifters, put everything back together + parts (hydraulic lifters + gaskets), then adjust them, is almost a full days work. So that price is OK for a marine dealer.
It's a under $200 if you do it yourself.
Gary
dockrocker 12-14-2005 02:28 PM
Gary
That's "under $200" if I don't screw it up! :)
Pat McPherson 12-14-2005 02:50 PM
You won't screw it up...
But I will say that most 1996 BBCs are Gen VI roller motors and a set of roller lifters are more than $200.
Gary Anderson 12-14-2005 03:02 PM
Oops, 96 was start of Gen VI. Yep they'll be more than $200, especially if you buy Merc parts.
GOODT 12-14-2005 04:30 PM
1 Attachment(s)
before you go through all of the head aches of changing lifter(s) check and make sure thats what it is and no just a worn out exaust flaper!!!!!! alot of times its mistaken for a bad lifter!!!!! and 800.00 is about right
Pat McPherson 12-14-2005 07:16 PM
That's a good one to check.
The rubbers is burned of the metal flappers inside my exhaust pipes and it does make a sould like a bad lifter.
cuda 12-14-2005 09:52 PM
I'm betting on a loose rocker as opposed to a bad lifter. If I convinced myself it was a lifter, I'd run a can of CD2 through it before I tore it down. It can't hurt. The bad lifters I have run across are usually from a piece of crap that blocks the oil passage to the lifter.
dockrocker 12-14-2005 10:05 PM
Lots of things to look at this spring - I'm sure I'll be back to this subject!
dockrocker 12-15-2005 07:19 AM
How do I check the flapper? I've got Silent Choice on the exhaust, if that matters. Thinking of it, I do have a new (used) exhaust manifold on that motor - old one had a leak that we giving me some milk shake oil. Could that contribute?
formula31 12-15-2005 07:33 AM
Ut oh, that opens a whole new can of worms. Any number of head or valve issues and wrist pin/piston galling potential.
Does the ticking go away above idle, say 2000 rpm? If so, it may very well be the flappers. Its been my experience that the flapper noise goes away once the exhaust flow pulses (back and forth-reversion if you will)are overcome by air flow (rpm).
Wobble 12-15-2005 09:14 AM
Two possible sources there. One is the diverter in the silent choice. Should be able to get hold of the lever mechanism with a gloved hand and see if that's it. Second is the flapper in the exhaust tip if its metal. Should be able to hear that outside the boat (on the trailer) Mine make a horrible racket up to about 2k rpm.
Wobble 12-15-2005 09:16 AM
Also the milkshake oil thing, could point you back to the valve guides, as the steam is hard on the valve guide lubrication.
