454mag, Gen V - Dyno Numbers?
I am looking for some information on a Gen V, 454mag Carbureted. Does anybody out there have a dyno sheet for this engine? I would love to see stock dyno numbers; and the dyno numbers with the 525SC cam installed in the same engine. Hopefully everything else will remain constant except the cam and a set of roller rockers and a carb.
Thanks, |
Re: 454mag, Gen V - Dyno Numbers?
Also,
I have Desktop Dyno, does anybody have the flow numbers for the stock 454mag Heads? |
I believe the 454/420HP has the same crane cam as the 525SC. With roller rockers and a holley 800 you should be around 420-430HP
razor flat tappet cams are OUT! & for good reasons, we now have mild to wild hyd rollers that can run well with low spring preasure and deliver more performance!
Originally Posted by RazorsEdge
Also,
