-   -   Lightweight Aluminum Flywheel (https://www.offshoreonly.com/forums/general-q/118806-lightweight-aluminum-flywheel.html)
88Fount33 12-20-2005 03:37 PM
I've got a 168 tooth SFI rated aluminum flywheel, neutral balance, tried it on a hot cammed small block boat and alpha drive, but lack of momentum coupled with bad idle charactistics of cam casused excessive stalling, so I had to switch to a 30 lb steel wheel. Currently building a 540 with neutral (interal) balance and was wondering if the higher mass of the 540 coupled with a soft shift trans would work. Would like to save the cost and weight of a new flywheel.
HARDCORE A/O 12-20-2005 04:06 PM
Re: Lightweight Aluminum Flywheel
I have a 15lb. Hays aluminum 168 tooth neutral balance flywheel on on my 509 with a 244 deg. int. duration (@.050") cam and I don't have any idle or stalling problems. I say try it.
amer3 12-20-2005 04:53 PM
i run one on my 496 no problems
ratman 12-20-2005 05:06 PM
i run alum flywheels on my 577n/a's with cranes biggest hyd roller 139661 no problems
Big Block Billy 12-31-2005 12:37 PM
I was told they work better on a jet boat. I have one that was externally balanced to a 572, that I'm not going to use. It can be re-balanced and weights can be removed. If anyone needs it let me know. Sometimes a smaller motor with a big cam needs the enertia of a heavy flywheel to idle well. A light flywheel gives better throttle responce. Has anyone ever tried running a 153 tooth flywheel, and change the starter to straight across bolt pattern? BBB
