CFM of quadrajet
Any one know the cfm of the stock carb on the 91 502 mag. motor.How much horse power will this carb support?
Re: CFM of quadrajet
750cfm
I've been told if you find the right guy to tune it, 425-450hp |
Payton is correct. They can be a very good carb.
I thought it was 850 cfm while the SBC's ran a 750 cfm??
I was told from way back from the folks at Jomar Engineering in the Detroit area that "Rochester carbs only come in TWO (2) different CFM sizes; 780cfm and 800cfm---period!" -----But I am not going to stake my life on what I was told so, take the info I have just given as you may.
But the real question that i've asked a hundred times is, how do you identify what size the carb is, based on looking at it?
I have a 1991 boat with a 502 mag. When i run the s/n of the motor by mercruiser they say it's an MPI motor, a '94. But it's carbed now, and i don't know what size the carb is. What's the number on top of the carb on you're 91 502, nordic95? |
1-3/32 in venturi (primary) 750 CFM
1-7/32 in venturi (primary) 800 CFM |
So if I have the 800 cfm ,how much horse power can this support?
| All times are GMT -5. The time now is 07:41 AM. |
