Needed bbc head
I an looking for a gen 4 bbc square port head or heads anybody have any
Re: Needed bbc head
kevin call G Hill 513 561 4849
Re: Needed bbc head
Not sure if you're looking for anything this extensive, but I have 2-pair (4-heads) 357cc AFR cnc ported with chamber porting, and exhaust port work work done beyond what the factory cnc porting has done, new Comp 930 valve springs, new 10* titanium retainers, and machine hardend locks, Ferrea 2.30"/1.88" stainless steel valves, new/fresh valve job, re-surfaced decks, 125cc chambers, flow bench numbers available. $3250 per pair. Let me know. Mark
Re: Needed bbc head
Hello,
I have a set of GM squareport BBC heads casting number is 14096188 they have been ported/polished with stainless and inconel valves hardened seats ready to go just add your springs. call me Emmett 757-484-7536 $750.00 |
Re: Needed bbc head
Hello,
I have a set of GM squareport BBC heads casting number is 14096188 they have been ported/polished with stainless and inconel valves hardened seats ready to go just add your springs. call me Emmett 757-484-7536 $850.00 |
Re: Needed bbc head
I have these sets
3986133 14092360 14096188 |
Re: Needed bbc head
I have a set of gen vi heads, rectangular port off a 502 mag efi. Gm number 140974088. They are complete with springs, rockers, keepers and o ringed mercury valve covers. Pm me if you are interested.
Re: Needed bbc head
I should have 1 good, bare, 990. I have a pair at the machine shop that were ported and flowed that were on a 572. They have 2.25 intake valves. I'm getting them redone to sell. They will have hardened seats, Bronze guides etc. Let me know if anyone is interested and I will have them built to your specs. The price will be according to parts and labor. If anyone is serious send me a pm.
The motor they came from is going to get dart heads. There is also another set that is still on the other motor. 15 hours, total rebuild(I can get specs) with the best of parts. No BS !!! I know I have a 990 head that some bozo beat in bronze guides that were too tight and have a few very tiny cracks at the base of the guide. I never pressure tested, but was from a running motor that dropped valve destroying other head. No evince of any leakage. Ported, Machined for 2.25 int. and I believe 1.90 exh. Anyone serious can make me an offer. Have many 049,781, and also peanut port heads if needed. Also have set of Rect. Merlin's that are mint. Have alot of valvetrain as well. BBB |
| All times are GMT -5. The time now is 10:06 AM. |
