-   -   Pictures Of side by side bolsters please ??? (https://www.offshoreonly.com/forums/general-q/118938-pictures-side-side-bolsters-please.html)
cougarman 12-22-2005 11:28 AM
1 Attachment(s)
Any body have pictures of different side by side bolster configurations?
Active Thunder makes one.
Sonic Makes one.
Outerlimits makes one.
Right Know I have a fixed three place in the front, and I would like to make it more accessable. I would still like to have it a three person set up. But I would like it insertable so you can still walk through. Also would like the arms cleared so you can pass from bolster to bolster with out actually climbing into the seat.
Unsure on putting the insert for the seat back on the end/ outside seat, or on the center seat.
Any and all Idea's, opinions, pro's, con's & pictures greatly appreciated.
Cougarman
Hot Duck 12-25-2005 12:32 AM
Re: Pictures Of side by side bolsters please ???
3 Attachment(s)
Here are a few pictures of our boat. It has the side by side front bolsters with the wheel in the middle. We do not have a removable section to add a third person up front like you are looking for though. I thought at first that it would feel funny running the boat from the center instead of being on one of the sides, but it is fine. I actually like it in this boat because being in the center gives you a better view of all of the gages.
Hot Duck 12-25-2005 12:40 AM
2 Attachment(s)
Here are a couple more older pictures of our cockpit setup. There are eight bolsters total. Two up front, four in the middle and two in the back row. We have an insert to cover the back two bolsters to create a sun pad when needed. The cockpit is a different color in these pictures, but the setup is still exactly the same.
Hot Duck 12-25-2005 12:44 AM
1 Attachment(s)
I found a picture of an Outerlimits that might actually help. It has a side by side setup with what appears to be a removable third front bolster. This sounds exactly like what you described. If I find any others I'll post them here.
