Bravo HP low water pickup
I have a set of bravo HP's with low water pick ups. They have IMCO shafts. After getting water in one of them 2 years in a row we found the lower case was slightly cracked.
Is this common with the low water pickup? I have several lowers but all high water pick up style. Should I chage both to high pick ups ( I have a 32 baja no steps). Does anyone have just a LWP housing? |
Re: Bravo HP low water pickup
I do not think the low water is more subject to cracks, I tried switching to high water and had heating problems with the engines. It all depends on how high the drives are mounted.
I think I would stay with the lows unless you find out more issues with them. |
| All times are GMT -5. The time now is 11:54 PM. |
