-   -   Gen 4 heads on a Gen 5 block (https://www.offshoreonly.com/forums/general-q/119265-gen-4-heads-gen-5-block.html)
Monkey Spanker 12-28-2005 07:47 PM
I know this has been kicked around a little before, but can someone show some pics of both a gen 4 head surface and a gev 5 block surface, and where the potential leak areas are? Someone out there has to have some spare parts to take some pics of.
jpclear 12-29-2005 08:48 AM
Re: Gen 4 heads on a Gen 5 block
Dennis Moore's BBC Marine Hi-Perf. book covers that all nicely with pics. Coolant leaks into the lifter valley. --- Jer
Monkey Spanker 12-29-2005 12:36 PM
Thanks, talked to TEAQUE today, and they first said sure with the right gaskets. But he went out back and talked to the mechanics and they said no way, it will definately not work. Now I have to change the whole motor..............
racinfever 12-29-2005 03:59 PM
gen 4 heads can be installed on a gen 5 or 6 block , use felpro# 1037 for 4.250 bore & 1047 for 4.500
Monkey Spanker 12-29-2005 07:10 PM
You know this question is coming, have you used these successfully? It would sure make things easier for me.
racinfever 12-30-2005 01:42 PM
SPANKER i wouldn't pull your tale on something like this ! if you need more info. email me and i will give you my phone ## :cool:
QUIKDECISION 12-30-2005 07:59 PM
I had a situation where I was going the other way around... I.E. Gen VI heads on a Mark IV block. I called the tech support at both Fel Pro ( Federal Mogul ) and Cometic... Cometic spent a great deal of time with me ( they were great ) in the end, they did not have a gasket recommendation... Fel Pro did recommend the 1037 / 1047 ( depending on std. bore vs overbore ) and stated that they have had good results either way, I.E. mark IV 's on gen 5 and 6 and vice versa. I upgraded my Mark IV ( 454 / 365 hp magnums ) to be identical to the HP-500...and topped it off with Gen VI heads. I had water problems in the oil. Blamed the heads at 1st. It turned out to be reversion. I pressure checked the head/block cooling system and the pressure was fine. All of that said, I am switching back to Mark IV
heads... My Gen VI heads ( rectangular port ) are going to be up for sale this spring.
vette4jja 12-31-2005 01:45 AM
Yes, with the right head gaskets you can put Gen IV heads on a Gen V or VI block. Wrong head gaskets you will have cooling problems. I know I did till I got the right head gaskets. I also had problems finding the right push rods.
vette4jja 12-31-2005 01:49 AM
Head gaskets to put Gen IV heads on a Gen V or VI block. Fel-Pro Marine, Gasket# 17048
Monkey Spanker 12-31-2005 09:05 AM
The 17048 is not listed for a 454 bore its for a 502 bore. But it still is not listed for a gen 4 head swap. But the 1037 does look like the right one. It's listed for all years.
