496 Mag Exhaust Manifolds, Performance?
Anyone have any reccomendations for upgrading the stock 496 Mag exhaust manifolds and risers?
I currently have a stock system with Corsa diverters and a Y Pipe. I have looked into Custom Marine's Sport Tube system, and they look *****en but pricey at 4K What about Eddie Marine Thunder, Gil Marine or some others?? Custom Marine boasts 50-60HP gain. Would you see some gain from these other Manifold Mfrs. if the Mag could breath better. Merc claims they are high performance manifolds and risers and the EMI Thunders look alot like the Merc stock manifolds. I have the standard 375HP 496 Mag and I just can't justify $4,500.00 for the Custom Marine Headers and install costs, I would rather spend 11K and pick up a fresh 496HO version. Any suggestions, Thx, R- |
Re: 496 Mag Exhaust Manifolds, Performance?
From Ray@Raylar:
I thought I might chime in here to kind of even out the questions of horsepower and torque gains from exhaust upgrades on 496's. First, keep in mind that for any motor to gain horsepower or torque it must basically get more efficient. Obviously any things changed on a motor that increase the volumetric efficiency can increase power. There are basically three types of marine exhaust manifolds, 1. The tradtional old mercruiser log manofolds that came on the 350 thru 502 carburated and MPI motors from 60's thru mid 90's. these manifolds because of their log (all exhaust ports dump close to the head into a long square chamber and then exit a back end up thru a small vertical riser entrance) are very innefficient, heavy (iron) and were poor at letting the motor develop hp and torque. 2. The aftermarket and new Mercury (Gil) short runner, center riser manifolds. These are aluminum units like Eddie,, Revolution Imco, Gil, CMI E-tops and 496 Merc., etc. they all have similar short runners 8" - 10" that merge into center riser openings and definitly flow better than the old log type most boaters have been use to. They will definitly make more power and torque than the old log manifolds. 3. The tubular stainless and special cast units with long 18" to 24" semi-equal length with good merge collectors, like CMI, IMCO Super Powerflo, Stellings, Eichert Bassett, Dana, etc. will generally flow exhaust more efficiently than either of the two other types. The real question here is the 496 engine. The stock 496 Merc (GIL) aluminum manifolds (type 2) are really pretty good units when compared to other (type 2) manifolds. Their individual runners and merge into the stainless steel round big radius risers with merge collectors can do a very good job of helping the 496 develop its great torque and good power. ESPECIALLY WHEN THEY ARE GIVEN EVER SO SLIGHT MODIFICATONS! If you were to take the turbulator plates alone out of the 496HO and dyno the motor you will see about a 15HP increase alone! So if you compare certain aftermarket manifolds (not type 3 tube headers) you will in most cases see no significant power increases from stock 496 manifolds. If you are looking for more Bling, polish or paint the Mercury 496 manifolds, polish the stainless risers and you have some good look'in aluminum manifolds that work well and you will save yourself about $1500 minimum. If your 496 is stock and you choose to step up to a good (type 3) header system you will probably see about 25-40HP net increase over the stock exhaust manifolds and risers with the "turbulators" removed, depending on your boats riser to transom configuration and muffler use if applicable. Trust me when I say that Raylar has probably made more dyno pulls on stock and modified 496's with many combinations of exhaust than probably anybody in the industry short of GM and I have the dyno sheets to prove it! We have made over 525HP on a normally aspirated 496 with stock Mercury 496 exhaust manifolds (turbulators removed and manifold riser openings lightly ported.) This is about the limit, normally aspirated, for these stock manifolds. If your plans are to go above 525HP with a 496 either normally aspirated or supercharged 496, then invest in a good set of (type 3) real headers or manifolds, you won't get there without them. I am not trying to endorse or critisize any aftermarket exhaust manufacturers here, I am just trying to get the real world results of their use on stock 496's where I have my expertise. Remember engines increase power from increased breathing and efficent use of fuel. The 496's need to breathe better on the intake side to make more power above 450HP and this will only come from improvements in heads, cams and intake manifolds, supercharger or turbo charger addtions . You are not going to get a 475HP from a stock 496 from just installing any set of headers and especially not from a set of $2000 manifolds. If you do, let me know how you did it. Just some real world facts! Best Regards, Ray @ Raylar __________________ "Nothing is impossible, it just costs more!" |
The old phrase, "you get what you pay for." The eddie marine is exactly that a manifold. Not a true tubular header. Swapping from the merc to the eddie marine manifold is like swapping paint jobs on two exact same motors.
You might want to check out Lightnings alternative to the CMI. You would see similiar performance for much less money:
Standard Lightning 496 Header - $1949.99 Satin Finish Stainless Steel 496 Header - $2995.99 Polished Finish Stainless Steel 496 Header - $3595.99 |
Thanks for the objective information.
I have removed the Turbulators and I think I will run as is until it is time to replace with the HO version or a 525. Where can I get my stock black Merc exhaust risers Poilshed to just dress it up a bit?? And how much would you think that would cost. Would the polishing effect the mating of the gaskets? Should Install new gaskets after the polishing and removal of the turbulators? Thanks, Robb |
Raylar,
So are the Stock Merc 496 Manifolds and Risers from the factory a Gil Marine Product? |
CP,
Does this come with the filter relocation kit? Another great post by Ray but I'll have to disagree with this particular quote... If your plans are to go above 525HP with a 496 either normally aspirated or supercharged 496, then invest in a good set of (type 3) real headers or manifolds, you won't get there without them. We are currently having a 750+hp Whippled 496HO with stock manifolds built (crank up ;o) by Peto that dyno's conservatively at 750hp with stock exhaust. Whipple has tested up to 800hp with no real setbacks from the stock manifolds. Supercharged and naturally aspirated are two different animals :D Thanks, Dave |
Yes the relocation kit is part of Lightnings package.
Feel free to call us for the real cost of the CMI 496 Header Kit.
We can supply you with plenty of data. Everything from dyno sheets to dozens of customers contact information who will gladly share the results the CMI's have made in their applications. Fred Trick Marine 866 921 4553 www.trickmarine.net |
Harper220 thanks for passing on Ray's info.
Rob' :drink: |
are the dana exhaust any good for a 502 :evilb: :evilb:
| All times are GMT -5. The time now is 05:13 AM. |
