-   -   Alpha limits (https://www.offshoreonly.com/forums/general-q/119859-alpha-limits.html)
johnsc91 01-06-2006 11:12 PM
Alpha limits
If choosing between stroking a 5.7l to 383 (350Hp / 400 ft lbs) and upgrading cam, rockers, etc to keep as 5.7l, which is best way to go? Alpha is Gen II & boat approx 3200 lbs. Do not want to trash the drive...
jpclear 01-07-2006 03:42 PM
Re: Alpha limits
Merc used Alphas with their 330 big blocks for a time and they did OK as long as you didn't try to log too much air-time or pull impressive hole shots. So I think a built small block would be fine as long as you drive intelligently. It was big torque that killed Alphas. DO install a drive shower, however! --- Jer
Full Force 01-07-2006 08:48 PM
Re: Alpha limits
I am going to put some power through an alpha too,I guess we'll see how they hold up!!
DasBoat 01-13-2006 06:08 PM
Re: Alpha limits
I've been turning an Alpha behind a small gas turbine engine for over 100 hrs, no problem. 320 hp 6000 rpm. Just back off when you catch air, ( the vertical shaft likes to snap) and take it esay on hole shots ( the upper gearsets strip out).
Shower a must and synthetic oil. My drive guy, shims the bearings a little tighter so the rollers don't "skate" across the races.
