-   -   Water Reversion (https://www.offshoreonly.com/forums/general-q/119997-water-reversion.html)
jchef 01-09-2006 07:25 AM
Water Reversion
If you drill holes in the stainless steel plates at the end of the Corsa stock mufflers for better flow and a richer sound is there a chance you could get water in the engine even with the rubber flapper.Would it be wiser to just change the tips? I have a small block 5.0 mpi with stock exhaust. Which would be the best tips to use for better sound and flow?
JS232 01-09-2006 07:35 AM
Re: Water Reversion
Remove the mufflers and replace with Corsa baffled angled tips :D
bobbarker 01-10-2006 07:38 AM
Re: Water Reversion
Reversion takes place when the engine is shut down caused mostly by too big a cam
