-   -   Compression Test 500EFI (https://www.offshoreonly.com/forums/general-q/120502-compression-test-500efi.html)
outriggers 01-15-2006 02:26 PM
I'm looking at used 500EFI, what should the compression be?It has 400 hours on it. Change valve springs? Anything else? I figure I would run it for a year or so then freshen it. Any idea what its worth? Thanks, Doug
GOODT 01-15-2006 02:39 PM
Re: Compression Test 500EFI
compression should be ideally over 150 with all cylinders within 10% of each other cylinder will fire with approx 100 psi realistically comp with 400hrs will prob be closer to 125.
really you should do a leak down test it will more accurately give you a better idea of the cond of the motor
Dave_N 01-15-2006 03:43 PM
1 Attachment(s)
From the Merc 500EFI Service Manual
GOODT 01-15-2006 05:37 PM
......still stand by what I said....how many 400 hr motors do you know with 175 psi fresh broken in mtr yes........
offthefront 01-15-2006 07:14 PM
Hey GOODT ..... maybe we should get your old Buddy Mr Cozzi in on this thread ??? :D
GOODT 01-15-2006 07:49 PM
:evilb: actually we spoke hes really a great guy........
Dave_N 01-15-2006 08:19 PM
1 Attachment(s)
Joe,
I too was surprised that they called for a minimum of 175PSI. Seems high. It's also strange that it differs so much from the 525EFI Service Manual (below).
Dave
GOODT 01-15-2006 08:39 PM
and both have the same copression ratio.........
with compression test I still go by the gen rules that I was brought up with ie...over 100 cyl is firing but bearly...all cyl within 10 % but the best way to tell the cond of a mtr is to do a leak down test....
offthefront 01-15-2006 10:02 PM
yea ... he seems ok .... alot of friends here ..... I feel his pain though ...(52) .... not easy when the years pile up and you realize there is a stronger smarter YOUNGER generation ...........
GOODT 01-15-2006 10:09 PM
42 here not much younger and I can feel the years piling up also...... :cool:
bobbarker 01-16-2006 06:15 AM
I had my 572,s tested average 225 pounds comp. I thought that was high,but thats what tested.
Edward R. Cozzi 01-16-2006 10:47 AM
Hi Guys!
Joe is right on the money. A 400 hr. engine will only see 175 lbs. if the combustion chambers are loaded with carbon deposits! The numbers being consistent and in the 140s would satisfy me.
Ed
Edward R. Cozzi 01-16-2006 10:48 AM
Thanks, Joe...right back at you!
