-   -   Crower lifters (https://www.offshoreonly.com/forums/general-q/120616-crower-lifters.html)
KNOT-RIGHT 01-16-2006 06:58 PM
Crower lifters
Who can get Crower solid rollers?
I need two sets of 66293H-16
These are for mk4 offset with pressure feed oiling.
Thanks in advance
Gerry
mrhorsepower1 01-17-2006 05:39 PM
Re: Crower lifters
I am a WD for Crower and have them on the shelf. Thanks,
Dean Gellner
Gellner Engineering Marine Power
ratman 01-18-2006 11:58 AM
Re: Crower lifters
yo cave are you gonna dyno the new mills? how long before there gonna be running?
Strip Poker 388 01-18-2006 12:27 PM
Re: Crower lifters
Dean Gellner
Dean where you located?
Rob
mrhorsepower1 01-18-2006 03:04 PM
Re: Crower lifters
Rob
Rob,
We are located in Cleveland,Ohio.
KNOT-RIGHT 01-18-2006 07:40 PM
Re: Crower lifters
Dean Gellner
Thanks Dean
pm me your phone number
KNOT-RIGHT 01-18-2006 07:48 PM
Re: Crower lifters
Yes they will go to dyno.
I am working the heads.
new copper B seats
manley titanium valves Custom order atleast two weeks
Icconel intakes
PSI springs
Td shaft rockers
Guides with oring seal on intake
Once we get the flow on the heads we can select a cam
something in the 260-270 420 lobe at 114cl solid
Atleast another month till I start assembly
I need to order pistons but waiting on block to get
the finish bore size.
So much to do. I am WFO!
mrhorsepower1 01-19-2006 04:39 PM
Re: Crower lifters
Here's the number to the shop (216) 398-8500. I am always here. Thanks,
Dean
tomcat 01-19-2006 07:42 PM
Re: Crower lifters
caveman: I like your parts list. We were looking at a cam like that, but after working with rmbuilder ended up with something different. I assume you are using superchargers too. It's worth talking to him IMHO.
ratman 01-19-2006 08:35 PM
Re: Crower lifters
cave did you sell you 32 yet? i saw you had it listed on ebey. how did you do on the sale? get close to what you were looking for? sounds like your gonna make some ponies with the new mills. ratman
KNOT-RIGHT 01-20-2006 06:30 PM
Re: Crower lifters
What cam did he recomend?
Here is the one I am considering
ground on a 114http://www.cranecams.com/?show=brows...tType=camshaft
Trying to get as close to 1200 on pump gas.
I would settle for 1100-1150
mrhorsepower1 01-20-2006 06:44 PM
Re: Crower lifters
Caveman,
I have used that cam in many supercharged applications. Very good choice for a 540-557 cu.in. package with big chief heads, 8.2-8.5:1 comp., 7 plus psi boost . The next choice down I would go maybe 2 degrees less on both int. and ex. You will make the power you want. Thanks,
Dean Gellner
roarkace 02-10-2006 06:37 AM
Re: Crower lifters
if you are still looking for the crower rollars i have two used sets that have less than 10 hours on them
KNOT-RIGHT 02-10-2006 08:07 AM
Re: Crower lifters
Now ya tell me.
Thanks anyway.
Dont know what size pusrhrods I need yet thats my next move.
Dean gave me a great deal on the Crowers.
Gerry
roarkace 02-10-2006 10:18 AM
Re: Crower lifters
I'll try again,i've got two sets of push rods that fit these rollars for a tall deck block and Dart Alum heads.let me know the length you need and i'll measure mine.
tomcat 02-10-2006 04:35 PM
Re: Crower lifters
I looked at that cam too, but I really wanted to take a stab at optimizing valve events for the centrifugal system. We ended up with less duration than you might think and found that we could not use anyone's master lobes. So the cam is CNC ground. We will test to see how it compares.
articfriends 02-10-2006 04:59 PM
Re: Crower lifters
I don't think you'll be dissapointed. Rm builder specc'd my hydraulic roller cam and it was barely bigger than what I was previously running BUT I told him I wanted to make 900 hp around at 5600-5700,he looked at my combo I was planning on using,did some number crunching and said the cam he had ground for me should make 925-950 hp around 5600-5700 and idle almost like a stocker. When I dynoed it we made 942 hp at 5700 so he was DEAD on,Smitty
KNOT-RIGHT 02-10-2006 06:28 PM
Re: Crower lifters
I,m a player for the pushrods lets see what I need
I should have the heads back late next week.
I,m running TD Shafts with tall decks with Dart Chiefs.
KNOT-RIGHT 02-10-2006 06:34 PM
Re: Crower lifters
Tom, Have you done any 557cu 8.5 to one big chiefs with your setup?
What power would you exspect?
I was going to grab some 206B,s and run 15lbs.
Can you change my mind? :D
Gerry.
tomcat 02-10-2006 07:03 PM
Re: Crower lifters
The twin blower setup is on the way to Sterling right now to be tested on one of his 557 Big Chief engines. Currently he uses PSI or quad rotors to make 1500 HP. I have a good idea what we are going to make but I'm keeping that to myself for now... :D What's a 206B?
KNOT-RIGHT 02-10-2006 08:42 PM
Re: Crower lifters
206b is a PSI blower. The cam in this post is very similar to the cam Mike uses in his 557cu 1200/1500.
:cool:
Gerry
Good luck with it!
KNOT-RIGHT 02-10-2006 08:55 PM
Re: Crower lifters
4.375 Bryant Billet Crank
Carrilo rods
4.5 bore
8.5 to one Ross Blower pistons
CFE Ported Big chief Heads
Titanium intakes coper seats
Iconel exhaust valves
crane 254/262 420 lobe ground on 114 Solid roller.
Whipple Double intercooler
PSI 206B.
Twin 1150 dominators
I have a pretty good idea what this will make
But I will keep it to myself :drink:
tomcat 02-10-2006 09:54 PM
Re: Crower lifters
Gerry:
Sounds like 1500 HP to me. :D
The engine recipe is great, I mean really, how could it be any better? But when you've already got the best parts, more power can only come with higher boost. That means higher blower speeds, discharge pressures and temperatures. That's when all the trouble starts. Mike will soon find out if we can do any better.
KNOT-RIGHT 02-11-2006 07:24 AM
Re: Crower lifters
Gerry:
I beleave your on your way.
Please Pm the results and some pricing on your
complete big gun package.
Thanks Tom
Gerry
