-   -   engine submerged (https://www.offshoreonly.com/forums/general-q/120695-engine-submerged.html)
tuffenuff355 01-17-2006 05:31 PM
engine submerged
a friend of mine recently bought a boat that sank with twin 454[365]mags, Does anyone have an idea what he should do?thank you for any advise.
Catagory5 01-17-2006 05:40 PM
Re: engine submerged
Where the motors pickled as soon as they came out of the water?
375stinger 01-17-2006 05:48 PM
we pickled our 454 mags in the 375 12 years ago when it submerged in salt, and they ran for another 9 years....
tuffenuff355 01-17-2006 05:50 PM
as far as i know he as changed the oil a couple of times and says its still milky. i told him i'd get some advise from you guys
jpclear 01-17-2006 06:49 PM
Depending on how they were flushed it could come up milky for three or more oil changes. The BIG questions; Was it a salt water dunking, and how many hours (yes, "hours", not days) before they were serviced and fired?? If the answers are "salt" and "days"... Just fold, leave the cards on the table, and walk away. --- Jer
ratman 01-17-2006 07:11 PM
or if your a gambler go all in. if you can steal the boat and you should be able to if it was submerged, you can get the parts boiled in a good hot tank then media blasted and reuse most or the hard parts, cranks, rods, heads, blocks, etc. the other stuff ya have to buy new for a rebuild anyway. just my .02
monstaaa 01-17-2006 07:35 PM
if its e.f.i throw all the electronics out. there junk. if not now they will be. if its carb like he said ^
375stinger 01-17-2006 07:56 PM
ours was salt, or however much salt is behind our old house on big pass on siesta key, for a few days it was...
GOODT 01-17-2006 08:02 PM
big question does it crank and as asked above was it pickled if the answer is yes as stated above oil will be milky a couple more times after that you will need to run it and " steam" off the water because no matter how many times you change it there will still be a little water that will have to be steamed off.....or just rebuild and any electronics that had any power to them are trash...
wantsa311 01-17-2006 08:30 PM
Does it make a difference if the engines were running when the boat sank (it was stuffed) as compared to, say, sank when it was docked?
