gimbal bearings
1 Attachment(s)
Which way should these bearings go into the transom?Cut out towards motors or drives?And the books shows to super glue the tolerance ring to the bearing,is that right?
Thanks Nordic |
Re: gimbal bearings
Merc puts them in w/ notches towards inside of boat.Either way is fine unless you see a red dot on bearing carrier, then it faces out towards drive.
Re: gimbal bearings
The ones that came out had red dots,these do not.So the notches go towards the motor?
Nordic95 |
Re: gimbal bearings
Gots to get the ones w/ red dots,or else you'll put some hurt on your drive/gimbal.
Re: gimbal bearings
Don't forget to line up the grease hole.
Re: gimbal bearings
1 Attachment(s)
you need to line up the crush ring and the oil holes.....
heres the break down of the gimbel ring the fiber washers are#3 |
| All times are GMT -5. The time now is 11:37 PM. |
