-   -   Aftermarket risers for stock style manifolds (https://www.offshoreonly.com/forums/general-q/121510-aftermarket-risers-stock-style-manifolds.html)
jmherbert 01-29-2006 12:04 PM
Does anyone know of any aftermarket long risers that will fit stock (center rise) manifolds? I have seen some but they are too rich for my blood.
Vinny P 01-29-2006 12:26 PM
Re: Aftermarket risers for stock style manifolds
Imco makes a riser that fits stock Merc manifolds. I dont know how long they are. I would suggest you not waste your money with upgrades to Merc manifolds. Wait until you can get a good aftermarket manifold and riser set-up.
jmherbert 01-29-2006 01:44 PM
I'm a little nervous about reversion. Ill be running a Crane 284H (single pattern 228@ .050, .512 lift w/1.6 rockers, 112 lsa) in a 383. I can have some custom ones made where I work, but I am lazy.
Griff 01-29-2006 09:51 PM
I have seen the Imco risers that fit Merc manifolds and they are pretty short. Probably not worth it unless you can find a used set.
Gordo 02-02-2006 06:48 AM
I'd say you've already read the best advice.
Don't wast money on risers alone, spend a little more and get good performance exhaust and matching risers.
Such as these aor just under $1k per motor...
www.revolutionmarine.com
I've installed these on a number of boats with great results, plus they look great!
Or, depending on how much cam, you may want to go with CMI e-top lites
Olds Eddie 02-03-2006 10:01 AM
After ingesting salt water in my fresh water cooled SBC due to not enough static line, I got the IMCO's with the 6" rise. I am running a big Comp Cams hydraulic roller and have had no problems with reversion. I bought mine through Teague's and they discounted them a little. I had them weld in bungs so I could drain them to prevent freezing and they were still under $1000.
Payton 02-04-2006 07:49 AM
I like the Revolution marine exhaust as well. Another option is a set of used Gils. They can usually be bought for around $500 with risers. Just make sure you presure test them.That's what I did. I stripped and repowdercoated them. at the end of the first season I had one develop an internal leak. I was able to repare it. Everything considered, you might be as well off with the Revolutions.
Tedster 07-27-2011 08:47 PM
I asked this very same question on Performance Boat Fourm and got zero replies. Must be a challenging question for some. I learned alot about it here. Thanks!!!!!!!
pqjack 07-28-2011 06:33 AM
eddie marine used to make them too....dunno if they still do
ken sampson 07-28-2011 07:45 AM
Risers
I have a long set of Gil-Merc risers for sale. Like new used in fresh water asking 300.00
Ken
