-   -   Will the stock carbs work on these hp500s? (https://www.offshoreonly.com/forums/general-q/121594-will-stock-carbs-work-these-hp500s.html)
BajaRunner 02-01-2006 12:58 PM
Ive got 2000 hp 500's, just ported the heads, bumped to cr to 9.1 to 1, changed to a 731 cam, and bumped the rev limit to 5600, trying to prop around 5600.
1st test out we were running too rich, but at 5450 I hit a wall. Do you think i need more carb to get it over 5450? The stock carb is an 800.
Pat McPherson 02-01-2006 02:57 PM
Re: Will the stock carbs work on these hp500s?
I think if you want a 502 to make power up to 5600, you need more cam and more carb.
PatriYacht 02-01-2006 03:31 PM
Carbs might be ok but you need to go to the 741 cams. The 731 isn't much bigger than the stock cam. It's actually smaller than the 500 efi cam.
BajaRunner 02-02-2006 08:24 AM
The cams already in there. I have the stock gils and didnt want reversion problems.
benspeed 02-02-2006 08:30 AM
I agree 100%. 741 and a 950HP 4150
Griff 02-02-2006 01:29 PM
I think you are hitting the wall at 5450 because of the cam more so than the carb.
Nordicflame 02-02-2006 01:59 PM
Call and speak with Laz at Mesa Balancing...
They get some very big horsepower out of the 800 Holley on 540s.
Great source of info...
Dave
Pat McPherson 02-02-2006 07:18 PM
What he said...
I'd try bigger props; you may be pleasantly surprised.
I have a friend running a 731 in a 454. His boat seems to run fastest propped at 5300-5400rpm.
axapowell 02-03-2006 07:17 AM
I'm running the 741 (on the Dyno right now) with the stock Dart intake and the 800 carb and I am having NO problems with either reversion or the carb.
Sorry HP500's (502's)
BajaRunner 02-03-2006 07:57 AM
Damn, sounds like i should have done the 741, I just didnt want to be close to reversion, reliability is what i want with a few more ponies.
blue thunder 02-04-2006 01:58 PM
Sounds like with some tuning you should be near 5600rpm. Where is peak tq and hp with your setup?
BT :cool:
Bawana 02-04-2006 07:46 PM
Try headers, you can't suck more than you exhaust
