Merc 525sc water crossover
I am installing water crossovers on my 525sc's. How many of you with these motors run water dumps? Boat runs 90 now, will I have to much water pressure with out dumps? Bravo 1 drives w/dual water pick-ups. Not running t-stats. 1" plumbing.
Thanks for the info. |
Re: Merc 525sc water crossover
A friend of mine has the same setup in a 75mph 29' Fountain.
1/2" dump lines from the exhaust manifolds through the transom. |
Not running thermostats, I doubt if you'll have a problem. The restriction will then be in the tailpipes.
Make sure you install a restrictor in your thermostat housing otherwise your block may not fill up completly. Plus you want psi to dissipate heat.
Only way to know is to install water pressure gauge.
Too much pressure requires a relief device. |
Originally Posted by RLW
Only way to know is to install water pressure gage.
Too much pressure requires a relief device. My buddy sees between 5 and 15psi depending on rpm. He has a dash mounted water pressure gage. The water temp is still quite cool at these pressures. Before he added the dumps, the water pressure was 25+psi and the engine ran way too cold with condensation all over it. |
Originally Posted by Pat McPherson
Absolutely...
Originally Posted by DRIPPINWETII
Does he run a T-stat?
I think I may end up sticking with my circ pumps. My engine man says my motors will not warm up to temp until running WOT. Then dropping down to idle loosing heat and causing condensation in motor,"continueously "thus shortening engine life. Sounds like alot of headache and money for a few extra ponies and looks.
I may have a new set of crossovers for sale! :rolleyes: |
I think I may end up sticking with my circ pumps.:
10-15HP is not worth the effort IMO. The only down side to the circ pumps, that I can think of, is that they don't last real long (100-150hours) when they are run over 5000rpm. |
Consistent temps make more consistent HP. Stick with the circ pump.
Thanks for the help guys. :drink:
| All times are GMT -5. The time now is 05:56 PM. |
