-   -   Shorter drives and Water pressure (https://www.offshoreonly.com/forums/general-q/121701-shorter-drives-water-pressure.html)
Bryan Rose 02-02-2006 06:35 PM
At what point when installing IMCO -2 shorty would one start to worry about the H2o pressure ? Is it a speed thing or what? I currently have a low water pick up Bravo I and have no problems with this as of yet but if I install a shorty am I asking for water pressure problems and if so what is the cleanest simplest way to deal with it? Regulate it or dump it over .....need some help.
please advise.
Bryan
racinfever 02-02-2006 07:03 PM
Re: Shorter drives and Water pressure
leave the plug out of the speedo port , top of lower gear case!
Bryan Rose 02-02-2006 07:45 PM
Huh................................?
Strip Poker 388 02-06-2006 05:41 AM
I hear that the Imco will raise water pressure
Payton 02-06-2006 06:22 AM
and the Bmax crescent shortie doesn't. or so I've been told.
zt260 02-06-2006 09:42 AM
Use a pressure relief valve and dump the excess.
Hot Boat 02-06-2006 07:15 PM
My presure went up 10 psi with a imco 2" shorty. My stock drive was also a low water pickup
Bryan Rose 02-06-2006 07:32 PM
where to get and what kind?
zt260 02-06-2006 07:39 PM
Mine is from Teague, and feeds off the sea strainer. It's also adjustable from 15-30psi. You could just T it in line if you’re not straining. KPM racing also has some slick ones. Trick Marine can help with those.
